-   Convergent Design Odyssey (https://www.dvinfo.net/forum/convergent-design-odyssey/)
-   -   Audio Sync Issues With nanoFlash Files (https://www.dvinfo.net/forum/convergent-design-odyssey/506216-audio-sync-issues-nanoflash-files.html)
Steve Kalle March 19th, 2012 05:23 PM
1 Attachment(s)
Has anyone else had audio sync issues with their nanoFlash files and Premiere Pro CS5 (5.0.3 - last update)?
I recorded input #1 into both channels on my EX3 and the first clip is out of sync by 2 frames with the 2nd channel being delayed by 2 frames. Then, the 2nd file goes out of sync part way through which is shown in the attached image.
This is a major PITA to fix. I have had this issue once or twice before but nothing like this with over 2.5 hours of video from a single event.
Dan Keaton March 19th, 2012 05:29 PM
Re: Audio Sync Issues With nanoFlash Files
Dear Steve,
I will ask our lab manager to look into this.
Please provide us with the details, so he can attempt to duplicate this issue:
Camera
Embedded Audio or Analog Audio
MOV, MXF, or MPG
Firmware version, I assume 1.6.248
Codec (Long-GOP or I-Frame Only)
Bit-Rate
Frame Rate of video
Whether cranking or 3:2 pulldown or if any other special features were in use.
Steve Kalle March 19th, 2012 05:43 PM
1) Camera: EX3
2) Embedded Audio or Analog Audio= Embedded via HD-SDI
3) MOV, MXF, or MPG= MXF
4) Firmware version= 1.5.126
5) Codec= Long-GOP
6) Bit-Rate= 50Mb
7) Frame Rate of video= 29.97p
8) Whether cranking or 3:2 pulldown or if any other special features were in use= none. I had E to E Direct and Record PSF>Prog enabled. Max File Size was set to 100%.
I didn't update the firmware because I wanted to use the current firmware because it had been reliable in the past and I had no SxS backup for this event and the following night's event.
Dan Keaton March 19th, 2012 07:10 PM
Dear Steve,
Your nanoFlash firmware version, 1.5.126 was from June 2010.
Since then we have made changes in the audio sync.
However, we will still investigate this issue as I do not understand why the audio would be in sync at the start of a single file and then out of sync later.
