MOV conversion tool
Sorry if this has already been answered but I just wanted to confirm. If I set my NF to capture MOV files and the later use the file converter to convert to MXF will the MXF file be the same as if I were to originally capture MXF files on my NF?
Thanks, Garrett |
Re: MOV conversion tool
Hello Garret,
Yes the file will be exactly the same is if it was recorded with your nanoFlash, Since this occurs on a lower level, there is no re compression, and the files can then be taken and played back in the nanoFlash. (It is always best to format a CF card and use the converter to do a non-fragment copy back to the CF card) Best Regards |
Thanks Andy!
-Garrett |
| All times are GMT -6. The time now is 11:24 PM. |
