Panasonic TM900
Will this cam work with a nanoFlash? It has HDMI out so?
Ron |
Re: Panasonic TM900
Dear Ronald,
In 2D mode, yes the TM900 should work with the nanoFlash. |
Re: Panasonic TM900
In order to connect a TM900 to a nanoFlash a mini HDMI to miniHDMI cable is required. Is there a source for such a cable? Alternatively is there a connector to connect two miniHDMI / HDMI cables together?
Re: Panasonic TM900
I have found an adapter that converts HDMI to mini HDMI, they seem to readily available for around $10.
I can now use the cable that came with the nF - that problem is solved. |
Re: Panasonic TM900
Subsidiary questions. If I wish to intercut footage from the TM900/nanoFlash with footage from my XLH1/nanoFlash then presumably I need to set the TM900 to output 25p?
However, if I wish to intercut the TM900 footage, without attaching the nanoFlash, which is still attached to XLH1, could I intercut 50p footage? I edit, sort of, in FCP. Ron |
