-   Convergent Design Odyssey (https://www.dvinfo.net/forum/convergent-design-odyssey/)
-   -   CF Cards Shown As "Full" On nanoFlash, When Only Part Filled (https://www.dvinfo.net/forum/convergent-design-odyssey/491522-cf-cards-shown-full-nanoflash-when-only-part-filled.html)
Ronald Jackson February 10th, 2011 03:09 AM
I was using my nano this week, attached to my XLH1, as usual. Two CF cards in place, 64GB Transcend 400x.
One card had about 20 minutes of footage, the other was blank. After a few minutes of filming the nanoFlash stopped recording, and the LCD showed both cards as "full" i.e. solid black lines across the top.
The camera was still recording to tape, and a signal was being received by the nanoFlash, and output to my SDI monitor.
I reformatted the "unused" CF card then and there, and the nano started to record as usual.
Once home I played back off the part filled card and found my original 20 minutes of footage still in place plus a bit of the new stuff. I backed up the card to my Nexto, and although according to the nanoFlash this 64GB card was full, the Nexto only downloaded 20GB, corresponding to my "20 minutes" of footage.
Possibly unconnected, but I'm no expert, the nano during my recording session , of its own accord seemingly, kept showing "recording" and then "stopped recording", resulting in a string of tiny files/clips visible on playback.
Any suggestions as to what went wrong?
Ron
ps recording 180mbps "I" Frame and the "thin black line" on the LCD originally corresponded to my 20 minutes usage, so it went suddenly from this to "full"
Dan Keaton February 10th, 2011 07:41 AM
Dear Ron,
I feel that you accidently activated "Hot Swapping" by pressing the Record Button twice in succession.
As such, we immediate mark the card as full, and switch to the second card. This allows you to remove the one card and insert another.
This is covered in our 1.6.248 manual. Just search for Hot Swapping.
Ronald Jackson February 18th, 2011 10:04 AM
Dan,
It did it again today. I think I had a poor connection via the XLH1 Timecode Out socket, difficult to tighten up with the mounting plate in place, so inadvertently I must have pressed record (on the camera) twice and voila, both CF cards "full".
Given I have no interest whatsoever in Hot Swapping how can I avoid this in future? By reverting to an earlier firmware update?
Ron
Ronald Jackson February 18th, 2011 10:05 AM
Dan,
An afterthought, both cards showed as full, the part used one I was recording to and the other "unused" one,
Ron
Dan Keaton February 18th, 2011 11:43 AM
Dear Ron,
Yes, you could use our 1.6.29 firmware if you want to disable hot swapping.
I assume that you press Record twice in rapid succession, so we switched to the next card, then you again pressed the Record twice in rapid succession.
Ronald Jackson February 18th, 2011 02:29 PM
Thank you Dan as always for your quick response.
Do I just go through the Firmware Update procedure with 1.6.29 ?
Presumably available from the CD website,
Ron
Dan Keaton February 18th, 2011 03:16 PM
Dear Ron,
Yes, you can go to our website and download 1.6.29.
http://www.convergent-design.com/Dow...0/Default.aspx (Click on Downloads)
Here is the link to the firmware update procedure.
http://www.dvinfo.net/forum/converge...ml#post1612363
Willard Hill February 18th, 2011 09:04 PM
The same thing happened to me about three weeks ago, but only one card was affected. This explains why it happened, but I hate to change back to the old firmware as the new completely solved my problem with the unit powering up in cold weather. Now it is scary to think that with two mistakes in punching the record button that I could effectively be put out of business while out in the field filming wildlife.
On the positive side, I have filmed quite a bit since that happened with no further problem.
Dan Keaton February 18th, 2011 09:59 PM
Dear Friends,
It is clear that we should consider having an option to enable hot-swapping.
Of course the downsides of having an option would be that someone might only expect to record for a certain amount of time, then it runs over.
I am surprise that people are accidently hitting the record button (twice) while recording.
If one accidently hits it once, no harm is done, it just closes one file and starts another seamlessly, no frames are lost.
Maybe we need a two key sequence.
Billy Steinberg February 18th, 2011 10:10 PM
Are we looking at this the wrong way, perhaps?
Unless I'm misunderstanding the discussion, the problem isn't with hot swapping, it's with the "two pushes on the record button means skip to the next card". If you (and others) feel that this is too dangerous without providing a setting to enable and disable it, then the setting should control whether "two pushes" is enabled or disabled, not whether hot swapping is enabled or disabled.
Or am I missing something?
Billy
Dan Keaton February 18th, 2011 10:46 PM
Dear Billy,
If I understand you correct, you are suggesting that we just disable the function were the Record Key is pressed twice in succession.
If disabled, as I understand your position, then hot swapping could still work, just that one would have to wait until the card filled up, then the nanoFlash automatically advanced to the next card.
Billy, that is an interesting suggestion.
Using your suggestion, people who need to edit quickly, while still recording, could enable it, and others could disable it. An example would be camera operators covering breaking news.
Ronald Jackson February 19th, 2011 02:36 AM
Relieved to know that it wasn't just me having this problem. Like Willard I film wildlife (birds generally over here) which means an enormous amount of "record/pause" as the subjects continually move in and out of focus, and I think it is this that causes the problem. Typical clips may be only 10 seconds long, and no, I don't even think about naming each and every one!
I'll re install 1.6.29 pending I hope a further version with the option of enabling/disabling the "two push" scenario.
Power down is a handy option so sorry to lose that albeit hopefully not for long.
Ron
Dan Keaton February 19th, 2011 08:08 AM
Dear Ron,
For your application, if you want to start and stop so often, it would appear that one of our wired remote controls would be very helpful.
Do you already have one?
I believe that the switching to the next CompactFlash card signal can only be done via the nanoFlash's record button, not via the remote control (I have not personally tested this yet).
If this is true, then if you are not pressing the actual record button on the nanoFlash, then there is no possiblity of accidently activiating a "Hot Swap" request.
Other wildlife videographers tell me that this remote control is very helpful.
Also, with the remote control we have a mode that is even more useful for you type of shooting: frequent short sequences.
The nanoFlash System|Trigger|Remote Level opton, if used, will cause the nanoFlash to record when the remote control switch is held down. When released, the nanoFlash stops recording.
Thus, if you choose this option, you just hold the remote control switch down to record, release to stop, which would appear to be much easier for you type of shooting.
Willard Hill February 19th, 2011 10:39 AM
I was using the wired remote. I have a clip to mount it beside my Canon ZR-1000 on the tripod handle. This was during a heavy snow shower and I had draped a cover over the nanoFlash and most of the camera, so I don't know if I inadvertently hit the record button on the nanoFlash itself (along with punching the remote button) or not, but I was using the remote to fire the camera. I had not reported the problem yet as I thought it was possibly a one time glitch. I will test it when I have time to see if I can duplicate the problem.
Dan Keaton February 19th, 2011 10:41 AM
Dear Willard,
Thank you, I look forward to your test results.
Ronald Jackson February 19th, 2011 11:10 AM
I trigger my nano from the camcorder, either from the lanc controller on the tripod handle or from my wireless remote (that from my HV20) all to lessen the effects of camera shake. Thus I have a tape in the camera and record to that in parallel with the nano.
Yes Dan I do have a wired remote . Maybe I need to give it a go. Will this though mean I won't be able to simultaneously tape record?
Ron
Dan Keaton February 19th, 2011 11:47 AM
Dear Ron,
If you use the wired remote, it only controls the nanoFlash.
You would have to Start/Stop the camera manually, if desired.
Billy Steinberg February 19th, 2011 12:31 PM
Originally Posted by Dan Keaton (Post 1619678)
Dear Billy,
You understand my thoughts correctly. Again, it appears that the danger is accidentally pushing the record button twice, not that hot swapping exists. So a setting to prevent this type of accident should be deal with the cause of the "problem", not with the result of the problem (fix the cause, not the symptom).
Billy
Dan Keaton February 19th, 2011 12:56 PM
Dear Billy,
I wanted to use this thread to get thoughts from our users so we can come up with the best solution.
I find your comments to be very valuable.
I welcome other comments.
Lance Librandi February 19th, 2011 02:09 PM
Dear Dan,
I have also tried this and I believe the problem is the old fashion keyboard bounce. What about using the Right arrow key when the Nanoflash is in record mode to skip to the next card or close the file. This seems to me to be a much more appropriate key to use and would elevate the problem.
Dan Keaton February 19th, 2011 02:17 PM
Dear Lance,
Yes, that is more logical.
We are currently using the Left and Right Arrows, during record to adjust the Crank Rate if we are over or under-cranking.
Of course, over and under-cranking are not in use at all times. And over and under-cranking is a specialized activity and not normal used in conjunction with Hot Swapping.
Don Parrish February 19th, 2011 04:57 PM
"I think I had a poor connection via the XLH1 Timecode Out socket"
Is it possible that a loose timecode cable/circuit could trigger the effect by causing 2 quick timecode initiated start request ?
Dan Keaton February 19th, 2011 05:46 PM
Dear Don,
We could test that condition in our lab.
I doubt,however, that is the problem.
Our code to detect if the Record Button was pressed twice in succession is very different from the code to detect if we should start record based on incrementing timecode.
Ronald Jackson February 20th, 2011 03:15 AM
I'm absolutely no technophile, ignorance is bliss more like it, but Don's suggestion rings a bell with me and my XLH1. I have had connection problems, " No SR " message even though nano continuing to record.
Being out in the field (sometimes literally) gives no opportunity for a careful evaluation of what is happening.
If Dan is to test his XLH1 maybe include simulating a rapid series of"record/pause" with Timecode coming from the camera.
If I did this and something happened more a matter of "so what?" given my technical incompetence.
Ron
Robin Probyn February 20th, 2011 05:12 AM
Originally Posted by Dan Keaton (Post 1619941)
Dear Don,
So the forced top swop.. ie two quick pushes of the record button,can be achieved from the camera record button(when shooting internal media simultaneously) I also presumed it was only activated from the Nano record button only ?
Dan Keaton February 20th, 2011 10:45 AM
Dear Robin,
Sorry, but the forced Hot Swap to the next CompactFlash card can only be achieved by pressing the Record Button on the nanoFlash twice in succession.
While we need to do actual testing tomorrow, I am very confident that the above is accurate.
Pressing Record Button on your camera cannot activate Hot Swap.
Ronald Jackson February 20th, 2011 03:16 PM
I'm going to have to disagree with Dan.My difficulties with inadvertent hot swapping happened when I was not in any direct contact with the nanoFlash at all.
I (must have) pressed record twice,quickly, via either the Lanc controller or the camera wireless remote.
Ron
Dan Keaton February 20th, 2011 03:20 PM
Dear Ron,
I went back and read some of your earlier posts. I stand corrected.
We will do our best to test this tomorow.
Ronald Jackson February 24th, 2011 01:51 AM
Re: CF Cards Shown As "Full" On nanoFlash, When Only Part Filled
Any progress? Busy time as always I suppose. Would also like to know how Olaf is getting on with his improvement to the mounting bracket.
Ron
Dan Keaton February 24th, 2011 03:38 AM
Dear Ron,
I will ask our lab to post their results of the testing.
