-   Convergent Design Odyssey (https://www.dvinfo.net/forum/convergent-design-odyssey/)
-   -   export issues! (https://www.dvinfo.net/forum/convergent-design-odyssey/487853-export-issues.html)
Joe Batt November 22nd, 2010 03:00 AM
export issues!
1 Attachment(s)
Hi, I just started using the Nanoflash and have run into trouble. I'm using FCP. I downloaded "add movie" and the XD Decode. I'm throwing that out there because it may be contributing to my problem. I have since trashed add movie and don't know how to trash Xd Decode. but anyway here's the problem. I import footage from nano into FCP as XDCAM 422. everything is fine until I export. When I do, I get four files every time!
(PLEASE SEE SCREEN SHOT)
the movie info is spread across the four in some weird way. two are small and wont open, one is huge and won't open and one is small but opens the movie. deleting any of them causes the movie not to play. The file "morefintests" that you see is from compressor which still (so far) seems to work fine. Can anyone please tell me what's going on? One more thing, I've been using FCP for years and it's been smooth sailing. Anyone who helps me solve this is my hero, I'm going crazy.
Dan Keaton November 22nd, 2010 06:47 AM
Dear Joe,
I have read your post.
But, I am not the best person of our team to help with your FCP + Add-Ons problem.
Another member of our support team will be in the office in a couple of hours.
We welcome suggetions from others.
Greg Booth November 22nd, 2010 08:51 AM
Hi,
I don't believe Calibrated{Q} XD Decode would contribute to this problem - however XD Decode is not meant for computers with FCP - as FCP already comes with Apple's XDCAM codec.
The uninstall instructions are on page 8 of the User Guide online in the link below:
http://www.calibratedsoftware.com/do...-UserGuide.pdf
and also in the /Application/Calibrated/Docs folder after installing the software
But basically, you just:
1. Delete the Calibrated folder from the /Applications directory
2. Delete the CalibratedXDCodec.component from the /Library/QuickTime folder (that's the Library folder on your Main Harddrive NOT the Library folder in your User Directory)
3. Restart your computer and you're done.
Cheers,
Greg
Calibrated Software
Dan Keaton November 22nd, 2010 09:11 AM
Dear Greg,
Thank you for your assistance.
Rafael Amador November 22nd, 2010 11:32 AM
Originally Posted by Greg Booth (Post 1590655)
Hi,
Greg
Calibrated Software
Right.
They interfere with each other when on the same system.
rafael
Joe Batt November 22nd, 2010 11:38 PM
thanks guys, I removed xd decode and that wasn't the problem. I still can't figure it out. so weird....
Rafael Amador November 23rd, 2010 06:11 AM
Are you exporting to an USB HD or to any FAR-32 formatted HD?
Rafael Amador November 23rd, 2010 10:56 AM
Sorry.
FAT-32 HD.
rafael
Tommy Schell November 24th, 2010 02:02 PM
I ran into a similar problem the other day - tried to export out to a CF card (FAT 32), the exported file was larger than 4 GBytes (max size for FAT32 file system), and so Final Cut broke it up into smaller files similar to the earlier screen shot. When it was done, Final Cut was hung, and I had to re-boot the system.
Tommy Schell
