Got my NanoFlash at DVinfo.net
Convergent Design Odyssey
Old October 25th, 2010, 10:42 AM   #1
Got my NanoFlash
Just took delivery of my NanoFlash.
Looking forward to using it with my EX3.
Might need a bit of help, if I'm stuck setting it up.
Anthony McErlean is offline   Reply With Quote
Old October 25th, 2010, 10:59 AM   #2
Just in case you haven't found this page yet. Here is a place to get the most current nanoFlash manual as well as the Convergent Design FAQ on the unit and so on...
Manuals | Support | Convergent Design
The manual is very good at coaching one in setup.
Congrats!
Old October 25th, 2010, 11:12 AM   #3
Thanks Andrew.
I notice there are a few screw holes on the top of the NanoF, will the rain not get in here?
Old October 25th, 2010, 11:56 AM   #4
Anthony,
Congrats on the Nano purchase. I have been using mine with great results since it came out.
As for the holes on the top I would not use the Nano with out a waterproof cover. The Nano on its own is not safe to use in the rain. There are basic ways to cover up the Nano. I have a heavy zip lock that I put over it if there will be moisture. This keeps it covered and lets it vent at the bottom where the cables come out and I can see and use the screen.
Paul Cronin
www.paulcroninstudios.com
Old October 25th, 2010, 12:15 PM   #5
Thanks Paul, good advice.
I'll have a look for something on the net.
Old October 25th, 2010, 02:07 PM   #6
Clip Browser can check for errors with CRC enabled.
Is there anyway the NF files be verified at the copying stage too?
Does the NF cut the MXF files into 00:13:19:05 segments?
Old October 26th, 2010, 06:59 AM   #7
Sponsor: Westside AV
Hi Anthony,
Congrats on the NF. As far as rain cover goes, there are many solutions, this may sound stupid, but I use a clear plastic bag for my whole setup, camera and all. They are cheap small and deploy fast, and can be customized easily with tape or rubber bands. I shoot a lot on boats in salt water with Stedicam, the custom bagging works great.
In the winter here it is very cold so I sometimes use a "Polar Bear cover" from Portabrace, it is a big one from the 90's made for betacams, but it works very well with my EX3 + NF setup complete with hand warmers. I have tried many different Kata, Petrol, PB etc. covers/skins, but I have never found one that is good for a custom EX3/1 setup with NF mics etc. So I stick with the 15 cent solution.
As far as copying the files from CF cards or even just BPAV folders, from SxS cards. I never bother using CRC checking.
I have copied thousands of files v/o error checking and never had a single problem. I always copy to 2 drives, I just drag and drop the BPAV folder (this is from SxS cards) to one drive and rewrap the files to another as .movs, even in the field, if I have to. I find with the 64GB CF cards I can go all day so it is easy to copy at night when I am not rushed. I like the fact that I dont have a BPAV folder to deal with with the NF.
Maybe I am just lucky, but I have shot thousands of hrs this way.
One note, always reformat the CF card in the NF after it has been in a computer. This is easy to do and keeps things running smoothly.
Old October 26th, 2010, 07:19 AM   #8
Anthony,
I am with Olof, the plastic bag is the best solution I have found.
I also just copy files to my Raid 3 working drive then to a G-Safe Raid 1 drive be it BPAV or .MOV from Nano. It is rare I copy the BPAV since the Nano has never failed me.
Paul Cronin
Old October 26th, 2010, 08:11 AM   #9
Thanks Olof and Paul,
For the tips and advice.
I copied a 32gb CF card to PC in 17mins with the supplied USB adaptor. I'm happy with that speed.
So, copy the CF cards to the PC and then a simple copy and paste after that, OK thanks.
Thanks again.
Old October 29th, 2010, 07:27 AM   #10
Yes, this is normal for the NF to do this.
Old November 15th, 2010, 03:33 PM   #11
Best way to fill the holes.
You know the NF has a few holes in the top and side.
I would like a wee black head screw to seal those holes or a rubber grommet.
Would it be OK to do this?
Thanks.
Old November 15th, 2010, 03:47 PM   #12
Dear Anthony,
Those screw holes are M3,.5 Metric 3mm, .5mm thread pitch.
However, those screw holes are completely sealed already.
Those are captive screw inserts which are pressed into the case.
These insert protect the nanoFlash from screws that are too long (using normal force).
They are not open holes.
Dan Keaton
Augusta Georgia
Old November 15th, 2010, 03:58 PM   #13
Thanks Dan, as usual.
Not open holes. I didn't know that, but now thinking, that doesn't surprise me knowing how fantastic this NF is.
OK Dan, I have nothing to worry about then.
Thanks.
Old November 19th, 2010, 04:23 AM   #14
BNC 75 Ohm Elbow Plug to Jack Adaptor
I would order this BNC 75 Ohm Elbow Plug to Jack Adaptor ...if its the correct one.
I think I'm not allowed to post a link but hope its OK to do this.
Product code: BPJRAA75 (into Google)
Thanks in advance.
Old November 19th, 2010, 06:44 AM   #15
Dear Anthony,
If you want a 90 degree BNC adapter, that would be one that I approve.
Dan Keaton
Augusta Georgia
Dan Keaton is offline   Reply
