No SDI Sig on bars setting
Just made a discovery.. re my problem the other day.. when no TC -last Tc trigger didnt work..
On HDX900 Moni out HD SDI .. the nano gives No signal reading when bars and tone are set.. and so doesnt record.. bars and tone off..totally fine.. Would there be a reason for this? |
Dear Robin,
Yes, we do not feel that the HDX900's Color Bars are fully compliant with the the SMPTE Spec. As far as I know, the nanoFlash will show No SRC when the HDX900 puts out Color Bars. |
Hi Dan
Yes thats exactly what happens..and was the cause of my problem re TC trigger.. was sure I had recorded bars to the nano but obviously I couldnt have! What is not right about the HDX900,s bars and tone that Nano doesnt see it.. Thanks again for your time |
Dear Robin,
I do not know what is wrong with the color bars. I will check with our engineers tomorrow. |
Ok thanks!
Dear Robin,
I asked Mr. Jim Bridges of Type A Media in Atlanta to run a test with his HDX900 and nanoFlash. He started the camera rolling, the nanoFlash started recording, then he went into color bars and tone for 10 seconds, then stopped recording. The nanoFlash recorded the color bars and tone. He did not have the "Supers" on at the time, so there was nothing superimposed on the color bars. The color bars and tone were recorded and Jim checked the file in his editor. I recommend after recording color bars to stop recording, then turn the color bars off, then start recording, when appropriate. |
Dear Robin,
I have discussed this issue with our engineers. If you have "Supers" on, thus showing the viewfinder data overlaied over the Color Bars, and you are setup for 24p or have nanoFlash "Pulldown Removal" on, then the nanoFlash may not lock to the HDX900 signal, thus preventing you from recording the colorbars. Could you please provide more information? What Frame Rate? Do you have "Supers" on? Do you have "Pulldown Removal" on in the nanoFlash? |
Hi Dan
Yes I was shooting 24P..and did therefore have the remove pull down.. to get 24P from 30P From mono out I dont have any super,s as I understand they would be recorded !! But I do have my name,and time set to be supered for bar,s.. Must do a check with 25P.. Iam almost sure I have recored bars and tone to the nano in 25P.. which would not have remove pull down checked I believe? Thanks again Robin |
Dear Robin,
You could run a test without extra information on the color bars. Or run a 25p test with no pulldown. |
All other frames rates are fine for bars and tone..
25P with remove pull down still checked also works.. All with super on Looks like only 24p.. remove pull down checked,,(which it has to be) doesn't work.. cant seen anywhere to easily turn off supers.. I have only my name.. and date/time..supered onto the bars.. but anyway that doesn't seem to matter.. But a combination of 24P and remove pull down.. for some reason the nano doesn't see the signal..? Not the end of the world.. just wish I,d known before that shoot! Thanks |
Dan, I received a call from a NanoFlash owner today who just discovered the same problem with no having color bars when recording 1080 / 24p with the HDX-900. He was looking for an answer. I think I remembered discovering this before in the past, but could not remember why and when this occurred. Must have been a non issue. My curiousity is now turning and wanting to know why this happens.
Dear Dusty,
We do not currently have a HDX900 in our lab to test this. Our Chief Engineer told me that this ocurrs when the Pulldown Removal is checked on the nanoFlash, and the camera is set to 24p, and the "supers" are on. The "supers" are any characters superimposed on the color bars. We can not lock to the incoming color bars under these conditions. The reason is that the color bars are being put out at one frame rate and the "supers" at another, according to our engineers, thus making it hard for us to determine the pulldown pattern. One test that you could run is to start recording a scene, without colorbars, then switch on the color bars. The other test is to turn off the "supers". I will attempt to find out how to turn off the "supers" by reading the HDX900 manual. |
Dear Dusty and Robin,
I have been attempting to find the setting that puts the "supers" on the color bars. I do not have a HDX900 at my disposal to test this, but after reading the manual, I think the following menu item applies: Menu|Main Menu|VF|VF Indicator 1|Camera ID This can be set to Bar or Off Please set this to OFF, to prevent the Camera ID being superimposed on the Color Bars. I found this on Page 117, in Section 7-4-4 in the Panasonic Operating Instructions for the HDX900 manual. I feel that if this setting is set to Off, then our Pulldown Removal function will not be confused by the Color Bars coming out at one frame rate and the Camera ID (Super) coming out at a different frame rate. I hope this helps. |
Hi Dan and Dusty
I found all other frame rates are fine with bars and supers.. only 24,meaning .. remove pull down.. being a problem.. Will check out the no super settings.. It was only a problem in that it through me on the day.. why wasn't the nano recording.. I had only used it at 25P before..which is fine.. Thanks for looking into it |
Dear Robin,
While you may have checked "Pulldown Removal" while you were sending 25p to the nanoFlash, it did not go into "Pulldown Removal" mode since this feature works with 24p only. Thus, there was no "Pulldown Removal" being used, thus the cadence of the video from your camera was not a problem, thus, we recorded your color bars without a problem. |
Dan and Robin:
As I mentioned earlier, I kind of remember running across this problem before. I'm on a project with the F-900 and won't have access to my HDX-900 for awhile, but I'm curious if in E to E mode connected to the HDX-900 with Color Bars and Supers on, if the Bars even show up on the thru put of the NanoFlash to a monitor? |
Dear Dusty,
In "E to E" mode, the HD-SDI Input is sent to the HD-SDI output, without any processing. This is an ultra-low latency process. The input goes to the output about a microsecond later. We do not do any processing of the input signal before we send it to the output. It is, however, re-generated and reclocked. Thus any weaknesses in the input signal, such as a low level or jitter will be corrected. However, since we can not sync to a signal, with Pulldown Removal Checked, one that is both 24p and 30p, then no, you may not see the Color Bars on the monitor with the Camera Id set to Bars. When it is set to Off, you should see the Color Bars. |
| All times are GMT -6. The time now is 07:17 AM. |
