How will the nano work with a pdw-f350
From what I understand it outputs 1440x1080. Will the nano record this as 1920x1080?
Dear Marshall,
Yes. The PDW-350 converts the 1440 x 1080 sensor data to 1920 x 1080 before it gets sent out as HD-SDI. All HD-SDI (if in 1080 mode and not 720p mode) is 1920 x 1080. Just to be clear, the newer PMW-350 (not the PDW-350) is a native 1920 x 1080 camera. |
Also, remember the PDW-350 / 355 record on disc at up to 35 Mbps in 4:2:0, while the Nano allows you to record the full 4:2:2 signal coming from the HD-SDI output of the camera.
