-   Convergent Design Odyssey (https://www.dvinfo.net/forum/convergent-design-odyssey/)
-   -   Head phone vol (https://www.dvinfo.net/forum/convergent-design-odyssey/474741-head-phone-vol.html)
Robin Probyn March 13th, 2010 06:49 PM
Head phone vol
Hi there
Cant see anywhere in the manual about where the head phone jack out volume is ??? presume its the up/down arrows.. but would this change some other settings??
Dan Keaton March 13th, 2010 11:16 PM
Dear Robin,
I will need to confirm the following information.
I believe that the Up/Down arrows, on the nanoFlash, while recording adjust the audio gain, not the headphone volume, and adjust the levels being recorded.
While this does affect the headphone volume, it would be inappropriate to adjust the gain to adjust the headphone volume while recording.
I do not believe that we have a method to adjust the headphone volume while recording, this is a menu item.
We will be increasing the range of headphone volume controllable via the menu option in a future firmware release. Our lowest headphone volume is not low enough for some headphones and situations.
Piotr Wozniacki March 14th, 2010 03:29 AM
Dear Dan,
Where in the menu do you adjust headphone volume ? The only audio-related settings are those for the analog audio. Or am I missing something?
Dan Keaton March 14th, 2010 06:55 AM
Dear Piotr,
To adjust the headphone output level use:
Audio|Analog Settings|Gain Out
Piotr Wozniacki March 14th, 2010 07:08 AM
Dear Dan,
Yes, I'm aware of this setting - but if it indeed also works with embedded audio (I didn't test that), I'd at least put it outside the "Audio-> Analog Settings-> Gain Out" menu branch. In the current official firmware (and in the latest Public Beta) it can be found there, and not where you're saying: "Audio|Audio Settings|Gain Out"...
Perhaps a cosmetic issue, but might be misleading :)
Dan Keaton March 14th, 2010 07:58 AM
Dear Piotr,
I corrected my post to say "Analog Settings".
I know it we could make to easier, and we will, as a complete menu revamp is planned.
The Headphone out is an analog output.
Piotr Wozniacki March 14th, 2010 08:02 AM
Originally Posted by Dan Keaton (Post 1499427)
Dear Piotr,
Fair enough, Dan :)
