Aaron, if I had the money or the potential income to justify the $5000, I'd order the Cinedeck tomorrow. $2500 I could swing and even justify to my wife!
I'm shooting with the JVC HD250, 4:2:2 10bit is the best that thing can push out. What are you shooting that has dual HD SDI? You must have some serious toys, my friend. Serious toys indeed... |
My camera is a Viper. I've been happily doing 4:2:2 8bit with my Flash XDR for months now. Lot's of good projects shot and a short film shot on the XDR. All with unbelievable quality, especially the short that used Zeiss digiprimes on the Viper. But it's a shame not to do 4:4:4 10bit log with the Viper. That's the highest quality. The HD250 is a super nice rig though. I shot a lot of stuff on my HD100 and loved that camera. It's not as high end as a 250 but the sensor and optical block are very similar and it can also do 4:2:2 8bit out of the component. Unfortunately the CD boxes have no analog input though. I'm really pulling for Mark Job (also on this forum), to complete his design for a quality portable recorder, but I think Mark is learning first hand just how tricky this small feat actually is. Let's face it, we can all do this with a Mac Pro, RAID and an AJA card but I've never been too interested in doing that. Tethered sucks. Portable is the way. |
The firestore? Really? I own a Firestore and it's a piece of junk compared to the Nano - poor build quality, breakable plastic and it's DV/HDV only. Add to that a dodgy firewire cable connection and a battery that lasts about 10 minutes in the field, with no way of turning off the annoying battery warning beep even when connected to power. The power connector is extremely iffy as well. Plus you're limited to the size of the hard drive installed. And when they first came out they were a lot more than $1000...
Quality field gear is going to cost more. R&D is not as easily recouped as with mass market items. |
Cineform Support for the Flash XDR
Hi Mike:
You wrote: "Hang on a bit longer, I think we'll get support for the CineForm CODEC in the near term. I don't have an exact date, but it's a work in progress." ....Can this support also be added to the Flash XDR Mike ? Also, can we implement my Cineform conversion routine proposal onto the Nano Flash and Flash XDR as well ? (Everybody scroll back and read the first page near the bottom where I propose a built in Cineform conversion routine and how that *might* function in a Nano and XDR via a firmware upgrade) |
Thank You Aaron :-)
Mark,
The NANO can record only MPEG-2, because thats his kind of processor. I don't know much about these matters, but I guess can not be re-programmed to output other kind of stuff. Mark, if you want catch the 10b Unc recording, your way is "Sheer". Is not the same to record 1.2Gbps than 370 Mbps. Cheers, rafael |
You can't tell me that a nanoFlash or even an S.two is all that much more difficult to design and manufacture than a Firestore. I'm betting no, it's not more difficult but yet the economies of scale put the nano and S.two at five and fifty times the cost of the Firestore. It's hard to grasp and accept the effect of economies of scale. This is precisely why a really good prosumer camera (a very complex device), sells for about the same price as a good mattebox (not a very complex device). |
No disrespect intended, but the nanoFlash is considerable more difficult to design and manufacture as compared to the Firestore. The Firestore basically copies the compressed data, generated from the camera, onto a hard-drive (or Compact Flash card). The nanoFlash, on the other hand, has a hardware CODEC engine, which compresses the raw HD-SDI video before writing to our Compact Flash cards. The nanoFlash, can therefore, support a very wide range of bit-rates, while the Firestore is limited to the output from the camera. The S.Two does not have a hardware CODEC, as it records in uncompressed mode. So, in theory, it's a simplier device, but you have have to deal with very high data-rates, which opens up a whole new area of issues and problems. The nanoFlash does cost more than the Firestore, but you do get considerable more functionality and features as well as substanially better picture quality. All that comes at the price of increased engineering and manufacturing costs. Best- |
What is likely to happen though, is that Cineform support for native nano/XDR footage will be implemented. This means you'll be able to record with the nano/XDR and then convert the footage to Cineform for use in post. It doesn't mean the nano/XDR will be turned into Cineform recorders. |
No ! No ! Aaron ! That's Not What I mean :-)
Hi Aaron:
No, I think you misunderstood my earlier post on the matter. I'm not saying that CD should add *direct recording* in Cineform to their device, what I'm proposing is they simply load a software XDCAM HD codec to Cineform software converter into memory in their boxes (Nano & XDR) and implement a simple conversion executable from the push of a button in their menu routine. It can't be *that* difficult to implement. I theorize it could be done. CD must inform us if I am incorrect in my proposal. |
CineForm Support for nanoFlash?
You are 100% correct. We do not plan to add support for the Cineform CODEC inside the nanoFlash - we don't have sufficient logic available. But, we are working with Cineform to make the transcode of our files as smooth as possible. Best- |
Just Load A Cineform Encoder Mike
Hi Mike:
Nope, that's *NOT* what I'm suggesting. Just get a simple executable software conversion routine to convert XDCAM HD CODEC to CINEFORM and load the executable routine into device memory with a software switch actuated from a button press on the Nano or XDR. (Scroll back and re-read my original proposal on the other page) |
Sorry a "simple" XDCAM -> Cineform software conversion routine is not so simple to implement. We do not have enough logic inside the nanoFlah or XDR to implement this conversion. Our recorders are fundamentally hardware based and do not have a high-power CPU. BTW, welcome to the club of developing digital video recorders. It's a bit more challenging then most people realize! When you get your first working demo, you're about 10% of the way to a finished product. Cheers- |
You're Right Mike
Hi Mike:
Yes, it's frigin hard to design your own SSDR ! So true ! Right now, all I'm aiming at is first working prototype. Once we're there, then we'll see. |
Mike, I made my original comment prior to testing the newer Mainconcept plugin for Premiere & AE. Having the MXF files work in AE is essential for me, so I was quite relieved to find the updated plugin working. And I should be ordering a Nano within the next couple of weeks.
| All times are GMT -6. The time now is 08:05 PM. |
