1280X720p ...
Did a shoot yesterday 1280X720-60p at 1/120 shutter and I can see scan lines in FCP ... any ideas on what's going on?
Dear Dean,
What was you setting for PSF-In or PSF>Prog? These are the same thing, it just depends on what firmware you are using. What firmware are you using? |
Dan ...
Dear Dean,
I suggest that you run a test with PSF-In, unchecked. Also, I recommend that you upgrade to our firmware version 1.1.154, but this should not make any difference with the symptoms you experience. I believe that the problem was having PSF-In checked. |
Dear Dean,
For 720p, I recommend that you have this unchecked. Please try it unchecked to see if the problem with the scan lines goes away. I believe they will go away. As far as I know, and subject to correction, there is no such thing as Progressive Segmented Frame in 720p, they are always true progressive, and thus PSF > Prog being checked would be inappropriate. I know this is confusing and our PSF > Prog (which stands for Progressive Segmented Frame to Progessive) is also confusing. We will be changing this. If we prove that unchecking this causes the scan lines to go away, then I will request that we do a better job and detect that the footage is 720p and ignore the PSF > Prog if it is checked. |
Just a side note, on my last shoot I did not have this problem and PSF was not checked. Lesson learned. all the best |
Dan ...
I may be wrong, but I think the psf doesn't affect to p720 at all.
the standard is p60 or p50. For interlacing monitoring, is read a field from each frame to get i60 or i50. rafael |
rafael ...
all the best |
