-   Convergent Design Odyssey (https://www.dvinfo.net/forum/convergent-design-odyssey/)
-   -   Adobe CS3/CS4 + MainConcept = Great News (https://www.dvinfo.net/forum/convergent-design-odyssey/467176-adobe-cs3-cs4-mainconcept-great-news.html)
Aaron Newsome November 20th, 2009 02:03 PM
Hi Paul. I am guessing you are doing something wrong. The prores files I exported are not distinguishable from the source file.
Paul Cronin November 20th, 2009 02:10 PM
Interesting Aaron I have tried a few other shoots I did with the Nano and with out the Nano and the clips in Prores HQ are very noisy.
Aaron Newsome November 20th, 2009 02:33 PM
Are you exporting the raw clips directly with Compressor or from the timeline in FCP. Also, I solved the FCP XML to Premiere issue too. Premiere is expecting an older XML format so it will choke on new XML format. I have a fix for this.
Paul Cronin November 20th, 2009 02:43 PM
I imported the clips to FC then put them on a Prores HQ timeline with no render needed. Then I export them out from the FC timeline.
But now I am sending the client MXF from the raw clips and I will buy them the plug in since it has to go Priority in 10 min. But figuring this out so next time I can use XML or other options works for me.
Aaron Newsome November 20th, 2009 07:53 PM
I tried this again right now. I can't see the difference between the original clip and the prores. Can you shoot a short clip and post both versions. I can post my clips you if like.
Paul Cronin November 21st, 2009 03:36 PM
Aaron,
I was on a shoot all day and again tomorrow. Monday I should be able to post the same clip from both but they will be downgraded for the web. If it still shows well it will at least make my point at what I am seeing.
Thanks for the help.
Aaron Newsome November 21st, 2009 03:43 PM
Paul, you can upload the clips directly to my server. There's terrabytes of storage there. You may want to shoot a short clip, maybe 10 seconds or so. Then the files size of the original and the ProRes will be pretty small.
Compressing them for the web really won't help me understand what's going wrong.
Paul Cronin November 21st, 2009 03:50 PM
Excellent I have a short clip and maybe tomorrow I will have a chance if not Monday will work. Out the door now.
Did you send my your FTP once before? I will see if I still have it or deleted it.
Thanks Aaron.
Paul Cronin November 23rd, 2009 08:48 AM
Careful in purchasing the plug-in from Main Concept.
You have to make sure they send you the correct link or you will end up paying full price.
Dan Keaton November 23rd, 2009 12:56 PM
Dear Friends,
I will attempt to assist anyone that has a problem with the reduced price offer for the MainConcept Plug-In for Adobe CS3/CS4.
Our contact with MainConcept is very responsive.
Please let me know if I can assist.
Paul Cronin November 23rd, 2009 03:06 PM
Dan,
Astrid helped me out. The problem is they do not have a options for buying with the discount. So they are in the process of adding that options. The store is run by a different company.
Astrid did a great job helping me.
And I have not heard from the client so no news is good news when it comes to how the plug-in works.
Paul Cronin November 25th, 2009 06:07 AM
Aaron I put two clips in your folder. Thanks for checking them out.
Aaron Newsome November 25th, 2009 11:49 AM
Looking at them right now Paul.
Stay tuned.
Paul Cronin November 25th, 2009 11:54 AM
Great just getting ready to send the hard drive out today.
Aaron Newsome November 25th, 2009 12:51 PM
Paul. I see what you mean. That ProRes422 file is unacceptable. I'm not sure what noise you're talking about but the jaggies on the building edges are enough for me to reject them.
I'm looking into what might be causing this now.
