HD Minicams
I would like to hear from everyone who uses HD mini cams on the flash XDR, we currently have and use, Tosh HD1, Ikonix, Modula HD Junior,Ikegami HD-L20 and Bradley BE-HD10 none of which are accepted by the BBC as HD!!!
So what are your exeperiences and are there any other solutions? Jonathan |
In what way are they not accepted by BBC? I've used the Iconix and it's terrific, can't imagine a BBC programme at any level refusing to use it if recorded to HDCam etc. or the XDR.
Steve |
HXR-MC1P feeding Flash XDR or NanoFlash is an option but I doubt that will get BBC approval either. Could try the JVC HM100, it is very small.
Johathan,
We use our own custom version of the HD-10 which uses prime lenses and is smaller than the well built Bradley design. We have had problems which we are hoping will be fixed with the firmware released today. We will be testing this tomorrow. We have had no problems using the Toshiba IKHD-1. We haven't found a client yet who likes the noisy Iconix, especially with the boat anchor CCU it comes with. It's too bad that the BBC guidelines preclude use of almost any HD POV camera short of the Silicon Imaging camera (I guess). We are in line for some of the earlier Nanos. I will test them with several of the HD POV cameras and post the results. Jeff Jeff |
Hd Minicams
I use the Tosh HD on my Polecam system. Pictures are cracking and in my opinion far better than the Iconix. I work a lot for the BBC and I suspect that someone has taken the desicion that any camera with a chip size less than 2/3 is not deemed to be HD. I recently spent almost a week prior to a shoot discussing 'what is hd?' with a production manager. HD programme makers are allowed 25% 'non HD' footage, when I turned up, the shoot consisted of my Polecam a DVC Pro HD and two Z1''s !!!!.
The proof is in the pictures. The Tosh looks great. |
I agree the tosh is good, its just the BBC guidelines so at the moment it is only accepted as SD and goes toward their 30% allowable footage.
Minicams
Jonathan, I am interested in your experiences with the Modula camera. I have had discussions with the project manager at Fraunhofer about that camera for the past two years. I have tried to contact the folks at both Wige and Easylook since their cameras are based on the Fraunhofer product. Could you tell me more about the Easylook/Modula camera, how is it powered, what are the maximum cable lengths, how is controlled (I really like the idea of a one piece instead of two like the Ikegami, Tosihba, and Iconix), etc. Also what about the Bradley, pros/cons.
Thanks David Rogers |
David,
We use the HD-10 a lot (like one Bradley uses). The Gophercam on NASCAR is based on that camera (a very highly modified version) for the past 2 years. The reaction we get from most video engineers is surprise it looks so good. When it is set to -3db gain it is very quiet. It can output basically any SD or HD format except 24p. Since the matrix in it is Sony blockcam (read handicam really) based, it matches very well with Sony cameras. The buildups for it we have developed allow SD/HD-SDI and component output. Bradley Engineering has a decent RCP for it but you can shade it from a laptop as well. Price of course is the best part, and it would make a very nice lightweight companion to the Nano. Jeff |
I'm still surprised by the negative comments on the Iconix, haven't used it much but stuff I did from it onto HDCam field recorder looked fantastic to me. Steve |
Steve,
The problems which I have faced with the Iconix are two. 1. It is noisy and does not cut well with other cameras. 2. The huge CCU precludes it's use in many true POV situations. A (1080i only) Toshiba CCU by comparison is much smaller. The HD-10 doesn't need a CCU as you know and combined with a Nano will be the ticket. It has one big advantage, it can do 24p. The more general problem with 3 chip, 1/3 cameras is the general lack of a good selection of HD lenses. There are a few, but the most common lenses used with any of those cameras, the 2.8mm and 4mm C-Mount Fujis are SD lenses. Chromatic aberration and resolution are noticeable problems. Your neighbor David Bradley has done an outstanding job adapting the single 1/3" chip HD-10, including one approach using a B4 mount. The camera was used by the host as the stabilized wire cam in the Olympic rowing events. It looked outstanding. We have also adapted the HD-10 using interchangeable 1/3" prime lenses and a waterproof housing. Jeff |
Well I'll have to take your word for it, maybe you've used it more than I have. I only did a couple of shoots with its underwater housing and it was cut in with Sony HDCam 750 and to me it looked great. If anything the only difference was it looked a bit sharp compared to the 750 with its filmic BBC settings. We had the suite of lenses that came with it and they all looked good to me. I'll give it a more careful look next time!
Steve |
I am purchasing a nano for use with a POV camera and am currently leaning towards the Toshiba IK-HR1S, as I need something that accepts a C-mount lens (I want to use the fujinon 1.8mm fisheye) and does not have a bulky and power-hungry CCU. Does anyone have any experience with that camera?
Jeff or anyone else, do you have any experience modifying the sony HD10 to remove the stock lens and convert it to a C-mount? I would be very interested to know if this is a fairly straightforward operation, the sony is several thousand dollars less expensive than the Toshiba IK-HR1S despite having fairly similar specs. |
Minicam HD
Jeff would you send me information on HD10 camera system.
Thanks David |
Mike,
We have completely redesigned the HD-10, reorganized it's boards, added a HD-SDI output board and rehousing it, minus the stock 10x lens. The current version we make takes a Elmo lens but converting it (actually rebuilding the lens mount) to C-mount would be very easy. I will find out today how tough it would be to make it with a C-Mount. I only saw a prototype version of the HR1S about 8 months ago and wasn't able to compare it to anything else. David, I'll get you info on the HD-10. It does match the info of what's on Bradley's site, only it is smaller, waterproof right out of the box, and has interchangeable lenses. Jeff |
HD Minicams
Thank you Jeff, I look forward to receiving the info.
David |
| All times are GMT -6. The time now is 10:56 AM. |
