-   CineForm Software Showcase (https://www.dvinfo.net/forum/cineform-software-showcase/)
-   -   2:2 pulldown for 720p25 (https://www.dvinfo.net/forum/cineform-software-showcase/98386-2-2-pulldown-720p25.html)
Serge Victorovich July 7th, 2007 06:59 AM
How i can change metadata (flag) w/o recompession stream with existing 720p25 avi encoded by Cineform to add 2:2 pulldown to every frame display twice (fake 720p50)? Thanks.
David Newman July 7th, 2007 09:26 AM
Why do you need to do this, as 25p in 50p project automatically add 2:2 pulldown when you turn frame blending off.
Serge Victorovich July 7th, 2007 10:25 AM
CineVision encoder accept as 1280x720 input only 50p.
I can change metadata in hex editor for mpeg2 but need solution for CF avi.
It is possible, David, manipulate with avi metadata header?
David Newman July 7th, 2007 10:32 AM
Unfortunately via the codec interface they are likely using, we can't lie about the number of frame and the frame rate. You will need to export to a new clip form Premiere as 50p,
1) open a 1280x720 p 50 project.
2) place your 25p clip on it.
3) Turn frame blend off for that clip.
4) Export to a new CineForm AVI.
Serge Victorovich July 7th, 2007 10:35 AM
Thank you, David! I'll try your recomendation.
