Master collection and CineForm
David,
As I pull down the CS3 master collection any words of wisdom or warning with P2kDL? |
There may be a minor update or two, but CS3 is mostly in good shape with CineForm support. There are a couple of components in AE we recommend removing -- as we believe they reduce functionality -- at least until we can code around them.
putting it on lappy for a test |
[QUOTE=David Newman;There may be a minor update or two, but CS3 is mostly in good shape with CineForm support. There are a couple of components in AE we recommend removing -- as we believe they reduce functionality -- at least until we can code around them.[/QUOTE]
Wich components you recommend removing? |
AE switched some of the media layers over the Premiere SDK, which is a good move, yet it doesn't seem complete to me, it seems slower, and get the curves wrong in 32-bit mode (all just my opinion.) The older API still works fine, the problem for AE is we use AVI files (they often suggest we use a different extension -- which might make them happy but no one else) and that means that AE's new AVI importers take priority. The AE modules are ImporterAVI.prm and ImporterDirectShow.prm, but as I don't have AE CS3 on my home PC, I can't tell in which folder they can be found.
