-   CineForm Software Showcase (https://www.dvinfo.net/forum/cineform-software-showcase/)
-   -   cineform PP2 bottle neck? (https://www.dvinfo.net/forum/cineform-software-showcase/92881-cineform-pp2-bottle-neck.html)
Russell Pearce May 1st, 2007 06:58 AM
Hi all, Ive captured cineform HDV 25pf from a cannon XH-A1 all fine,
however on the timeline in PP2 the audio drops out and repeats/loops on cetain parts, I know the original is ok, for the first 10 seconds it does this the cpu is hitting 100% then it drops to about 20/40% and it plays fine? seems like a bit of a bottleneck/buffer thing, not even sure its a cineform issue?
Cineform aspect HD 4.3 b76
PP2.0
AMD 3700 64
2GB RAM
7200 seprate drive
Russ
David Newman May 1st, 2007 08:35 AM
The timeline is buffering ahead of the play position which may be cause
Premiere to drop audio (Aspect does not handle the audio playback.) Within the playback settings reduce the about of buffering under this goes away. They may also be settings of the ASIO drivers of your audio card, but try the buffering control first.
Russell Pearce May 1st, 2007 10:52 AM
Reducing the playback buffer, problem solved , thanks very muchos :)
Russ
