-   CineForm Software Showcase (https://www.dvinfo.net/forum/cineform-software-showcase/)
-   -   AJA timeline monitoring options (https://www.dvinfo.net/forum/cineform-software-showcase/92827-aja-timeline-monitoring-options.html)
Tim Veal April 30th, 2007 04:42 PM
With the AJA LH, can you monitor the Premiere timeline with the component and composite outs as well as the HD-SDI out? Can you monitor both at the same time?
David Newman April 30th, 2007 04:47 PM
You can monitor component and HDSDI at the same time, but I don't think composite is enabled (never checked.)
Kevin Wild April 30th, 2007 09:11 PM
The composite uses the "Y" I think of the component, so you can't do component AND composite at the same time.
Tim Veal May 1st, 2007 10:01 PM
Thanks. Do you know if you can view a HD signal out of the SDI input and a SD signal out of the component from the PPro timeline at the same time?
Salah Baker May 3rd, 2007 04:38 PM
at 1920 you cant use component out only HDSDI
720 lets you use component out
Tim Veal May 4th, 2007 04:19 PM
Thanks. .
Kevin Wild May 4th, 2007 06:58 PM
Say what? Not sure what you mean by this, but you can certainly view 1920 x 1080 footage out via component. We do it every day...we never work in 720.
We have an Kona LHe.
Salah Baker May 5th, 2007 08:22 AM
Xena LHe Here
