@ DAvid: Which codec from Imaginate 2 for using in Cineform Pro 2 project?
When using File - Render Video in Imaginate 2 I can choose under codecs:
Cineform encoder-2 Cineform (Adobe) HDV encoder Cinefrom HD encoder Cineform HD Codec V. 2.9.1 Which codec should I use for using the file in Adobe Premiere Pro 2 in a Cineform project? Thanks very much in advance! Gildo. |
Never use "Cineform (Adobe) HDV encoder", as that is very old (use must have Premiere 1.5.1 as Adobe no longer ships it.)
Cinefrom HD encoder & Cineform encoder-2 Are DirectShow components -- if they work in that tool -- great. "Cineform HD Codec V. 2.9.1" is VfW codec -- likely the one to use for third party apps. |
Thanks a lot David,
'Cineform HD Codec V. 2.9.1' has given the best results so far. |
