Does PPro2 Multicam work with AspectHD 4?
Does PPro2 Multicam work with Aspect HD 4?
Have both installed, working great until you try Multicam. Everything works normally on Multicam until you actually press PLAY in the multicam window. After rendering, the timeline will go to the end and sit in black. You can scrub the multicam window time bar and watch multicam, but you can't actually do the cuts. It works just fine in DV mode and in native HDV mode. Just not with AspectHD 4. Any ideas? thanks |
Any ideas from anyone? Submitted a ticket a while ago but haven't heard back from Cineform....
Thanks |
I'm not back at the office yet, so I can't check on your ticket, however multicam is supported in Aspect 4 under PPro2. It will be on my list of items to check into.
Hi David.... welcome back.
Any update on this issue? Thanks Stacy |
Good news. Multicam support is fixed in Aspect HD v4.02 Build 54 which we just posted. It turns out multicam was working properly for 720p material, but not for 1080i. You should now be in good shape. You can pick up the update on our website. Thanks for bringing this to our attention - sorry for the headache.... David. |
David,
The update works and multicam functions. However, I have a question..... If I have two cameras and set up Multicam, how many streams is PPro/Cineform actually processing? Is it two or three? The reason I ask is that Multicam stutters something fierce when using cineform. When you make the cuts, it actually leaves little gaps between videos on the timeline. I have verified that I can easily process two real time Cineform files by putting two of them on a timeline and setting the transparency to 50% on the top layer than playing them back. No stuttering, no nothing. Just plays. Multicam doesn't work for me at all, in terms of stuttering. If I use standard m2t files with PPro's built-in HDV support, I don't get any stuttering on 4 streams. Any ideas? Thanks |
Multicam is not accelerated, just supported. Premiere is actually doing most of work. We might accelerate it is there is enough interest. As for the gaps, that is all Premiere as we don't modify the edit list.
David,
Consider me interested! JayH |
Either way I posted a screen shot of my current timeline with this error shown, it's JPG so you should be able to download it and zoom in on the timeline and see the error. http://www2.dj-miguel.com:8080/sp-pi...ER%20ERROR.JPG Miguel |
| All times are GMT -6. The time now is 08:50 AM. |
