Weird & Wobbly Horizontal Distrotion in Playback
Hi,
I can't find any mention of this in other threads but it's likely been discussed before. When I create a Cineform 1440x1080 project with footage from my Z1 (captured with Cineform) and I play it back, there is an unusual "wobblyness" to the image during movement or when playback is stopped. I can't post a picture but I can do my best to describe it; when a vertical line is on screen, like the edge of a wall for example, it appears wavy in the preview window. I have exported back to tape and the final product is fine but the preview window is affected and it is quite frustrating. Has anybosy had this happen? NOTE: I am not talking about the interlaced lines - I'm specifically referring to this weird wobbly effect. Vertical lines look like this: / \ / \ Now, when I use the same footage in Premiere's HDV 1920x1080 project, it works just fine and there is no wobblyness. I am assuming therefore that this is to do with the 1440 Cineform alternative to Premiere's 1920. Am I on the right track? Can anyone explain it to me? Thank you, -- John. |
It is interlaced issue when a frame is scaled into the preview window. Within the playback setting control panel, select "de-interlace" while scrubbing to see if the fault goes away.
Note : "1440 Cineform alternative to Premiere's 1920" -- HDV is 1440 by 1080 not 1920. |
I can see what you mean now about the scaling - simply moving and resizing the preview monitor has an affect on the severity of this issue. I suppose the only real 100% solutions would be to output via component to a TV or to have something like the Dell 24" with a high enough resolution to display the entire frame, right? But even so, even on a HD capable PC monitor like the Dell, the interlaced lines are still likely to appear, aren't they? Is watching the preview on a TV the only solution? |
The weird thing is you shouldn't be seeing any of this. What version of Aspect HD are you running?
I'm not sure, it's not mine that I'm using. I haven't purchased it yet (can't til I get my new computer) so I'm using a friend's computer who has it. I'll find out which version it is.
I thought that maybe it was a product of a 64Mb video card with a 2 year old CRT monitor - would that have anything to do with it? |
Sure. Something isn't "normal" so a GFX card issue or older software could be at fault.
how bout you take a screenshot and view it on another computer and/or post it on here? just to isolate the problem further.
I'd like to post a screenshot but I can't post attachments and I don't have any webspace.
Also, I found out that the graphics card is a more than capable (I think) nVidia 6600 but his version of Aspect is not current. He said it was "3.something" but wasn't sure what. |
He should upgrade to 3.4, it is free.
| All times are GMT -6. The time now is 12:09 PM. |
