-   CineForm Software Showcase (https://www.dvinfo.net/forum/cineform-software-showcase/)
-   -   Uhd to hd. Is there a dynamic range improvement (https://www.dvinfo.net/forum/cineform-software-showcase/536559-uhd-hd-there-dynamic-range-improvement.html)
Bob Hart February 3rd, 2019 05:13 AM
I have heard in conversation that originating in UHD then converting down to HD for assembly and edit confers an apparent improvement in a HD deliverable in terms of colour and dynamic range, versus originating in HD. I realise that the image will have improved apparent crispness but that was as far as I thought it went.
If anyone can point me in the direction of the correct theory and methods, this would be appreciated.
Steve Game February 3rd, 2019 08:57 AM
Re: Uhd to hd. Is there a dynamic range improvement
I suppose that it depends on how the downconversion takes place. If there isn't sufficient filtering before subsampling, the artifacts will increase the effective picture disturbance maybe appearing as increased noise. In theory, a sensor with 1/4 of the illuminated area per pixel will have a higher noise floor. If the scene is not very well lit, this might be visually detectable thereby reducing the effective dynamic range.
Pete Cofrancesco February 3rd, 2019 11:52 AM
Based on experience and common sense, down converting from a higher resolution doesn’t add color or increase dynamic range.
You can google “video color bit depth” for a more detailed answer
Cary Knoop February 3rd, 2019 11:59 AM
Converting UHD to HD can increase the bit-depth of the luma and chroma channels and reduce chroma subsampling.
For instance, an 8-bit UHD 4:4:4 video converted to HD becomes a 4:4:4 video with all channels being 10-bit due to oversampling.
An 8-bit UHD 4:2:0 video converted to HD becomes a 4:4:4 video but only the luma channel will be 10-bit, while the chroma channels remain 8-bit.
Dynamic range will not change.
Pete Cofrancesco February 3rd, 2019 12:38 PM
I remembered a while back there was a thread about the same topic. Someone on the internet put out this idea and it’s just a lot of semantics.
Let’s cut to the chase. If you want to color grade you need a camera capable of filming above 8bit.
Mark Williams February 3rd, 2019 03:22 PM
Don't know about measurable color and dynamic range improvements but a couple of years ago I shot a lot of 4k with my GH4 and brought into 1080 projects since I didn't have 4k compatible software back then. It looked vastly better than footage shot in 1080.
Gary Huff February 3rd, 2019 06:00 PM
Let's cut to the real chase. No one here is grading in any way that stretches the capabilities of 8-bit color. No, adjusting contrast/saturation and applying LUTs is not grading.
Aside from that, downsizing from 4K to 1080 will give you a better 1080 image on some cameras than the 1080 output, but that's it.
Mark Watson February 3rd, 2019 06:34 PM
As for getting some added bit depth, I don't believe it. And I've never seen an actual example of it working by anyone who says it is possible. Give me the details of what you did and I should be able to replicate the result.
I have downscaled from UHD plenty times and when I inspect the video properties, there's no magical 4:4:4 or 10 bit from 8 bit footage showing up. I have downscaled from HD to SD via software such as in Sony Vegas, Handbrake, Virtual Dub and TMPGEnc, and also via hardware methods using a special DVD burner that takes HDMI input and will downscale on the fly to burn immediately (as you're shooting) to a DVD and also with a Decimator MD-HX. Never got any of that 4:4:4 or 10 bit from 8 bit goodness.
I bought some 10 bit cameras.
What I DID see with a UHD to FHD downscale, was a nicer image than if I'd shot it in FHD from the same camera. More crisp, like it got a resolution bump. Another thing I found is that when shooting a low-light scene, the grain seemed finer, which made for a better result when running it through NeatVideo.
Cary Knoop February 3rd, 2019 08:17 PM
Just because you have used software that cannot handle this correctly does not mean it can't be done.
The chroma channels are already HD for a UHD clip, that's where the 2 in the 4:2:0 comes from, you only need to resize the luma channel!
So obviously the result will be 4:4:4, without doing anything to the chroma channel.
By having 4 samples in the luma channel reduced to 1 you increase the bit-depth by 2, it's called oversampling!
Gary Huff February 3rd, 2019 10:06 PM
Then you could clearly show a demonstration of this in action could you not? Oh wait, you can’t.
Pete Cofrancesco February 4th, 2019 06:53 PM
That’s presumptive to claim to know what everyone does and to speak on their behalf.
If you re read his post he is asking will downresing improve color and dynamic range. Which it doesn’t, filming in 10bit log and grading it, on the other hand, will do both. Whether it’s worth his time and money is up to him.
Cary Knoop February 4th, 2019 07:37 PM
It's very easy in Vapoursynth:
- open the stream
- apply a conversion filter to convert the bit-depth to float32
- apply a resize filter (resize only the luma plane to HD, the chroma planes are already HD)
- apply a conversion filter to convert the bit-depth to 10 bit
- export the Vapoursynth output stream with FFmpeg to ProRes 444
Gary Huff February 4th, 2019 09:06 PM
That's cool. I can do that in any number of programs. What you haven't demonstrated is any benefit whatsoever, and your method does not add anything to a clip that allows it to grade like a truly captured 12-bit 444 clip.
David Newman February 4th, 2019 10:27 PM
The effect is minimal, and it relies on noise or gradients that are not quantized away by the source encoder. e.g. 8-bit values in a 2x2 matrix:
[10,12,
13,14]
in 10-bit it contains no more inform:
[40,48,
52,56]
When downscales by 2 in each direction, these valued are averaged to:
49
Which only exists as a 10-bit value, as in 8-bit that would be 12.25.
If the noise is quanizated away:
[10,10,
10,10]
There is not more dynamic range to achieve through scaling.
As all common 8-bit sources are compressed, the scaling is less effective than the theoretically potential gain. From a compression camera you might gain about 1-bit, from every 2x2 downscale. Yes it is subtle. The other benefits of 4K shooting are more significant, but the math shows it is true, that precision preserving downscales can improve dynamic range.
Gary Huff February 5th, 2019 08:01 AM
Sure, the math may work out, but the math isn't what matters, the final image is.
Bob Hart February 5th, 2019 01:43 PM
Thank you everyone for contributing to this enquiry.
Bob Hart February 6th, 2019 03:43 AM
For a dumb cluck like me, could someone perhaps lay out the correct method in stages or blocks for the best downscale from UHD to HD and by what softwares if DaVinci Resolve free or Adobe Premiere CS6 do not provide the appropriate encoders.
I would like to try to avoid using commands in MS-DOS. I can if needs must but I inevitably will make mistakes. You get that way when the years pile up and you become a bit witless.
Camera origination is by Blackmagic URSA 4K ( big URSA ) which creates Cinema DNG and UHD ProRes files, also Panasonic AG-UX180, which creates it seems unique UHD files in MP4 wrappers. Whichever and whatever, the images look nice from both cameras.
Pete Cofrancesco February 6th, 2019 08:28 AM
In Premiere I allow it to create a sequence that matches the videos native resolution then I export it to whatever lower resolution I want. I find the standard settings work fine but you can experiment.
I use the latest version of Premiere, in CS6 I believe you need to create proxies for 4k. Might be easier to downscale in another program. I have the UX180 and often film in HD to avoid the extra time of editing and encoding. If I need to recrop uhd is very helpful otherwise film in hd. For me the extra time of downscaling doesn’t justify the added time and hassle of editing and encoding.
Gary Huff February 6th, 2019 10:28 AM
The Ursa does perfectly fine 1080, there is literally zero reason to film in 4K to downscale to 1080 unless you want the ability to recompose shots, in which case I would say you should film videos properly to begin with instead of relying on that crutch.
