-   CineForm Software Showcase (https://www.dvinfo.net/forum/cineform-software-showcase/)
-   -   Video is Splotchy (https://www.dvinfo.net/forum/cineform-software-showcase/50397-video-splotchy.html)
Peter Moore September 1st, 2005 02:59 PM
Video is Splotchy
I've got a serious video quality issue with the Cineform codec and Vegas that I hope there's a solution for. When I compare the M2T file directly to the Cineform file after conversion, side by side, the converted M2T file looks spoltchy, like the number of colors has been reduced. Especially prevalant on walls and solid colored backgrounds. Further, this is noticeable on export to any format, including MPEG-2, WM9, etc. Any way to fix this? Am I doing something wrong?
David Newman September 2nd, 2005 09:30 AM
Yes I think you must be doing something wrong as no one has reported this before. Are you using Connect HD 1.9, if not please try that first (download the trial from www.cineform.com.) If you still see he problem contact tech support by filing a trouble ticket a www.cineform.com/support.
Peter Moore September 2nd, 2005 12:19 PM
Here's an example of what I'm talking about
http://www.mooreusa.net/example2.jpg
Check out the splotches on the left wall. This does not appear in the M2T file. The M2T file has a nice clean looking wall.
Any ideas?
I suspect it has something to do with the YUV / RGB conversion but I thought this had been dealt with. I am also using the newest version of Connect HD.
David Newman September 2nd, 2005 02:01 PM
I would like to see the M2T file (can you upload a few GOPs with this frame -- you can use any file split tool if the original is too large.) Also are you using HDLink to do the conversion? Vegas will add a YUV to RGB conversion that HDLink will not. As you are using 720p, make sure the compression is set to progressive (not interlaced) and you might as well be using high quality.
Peter Moore September 2nd, 2005 02:05 PM
Ok I will do some work and get you those files. I appreciate the help.
I have been using Vegas for the conversion. Now, I can use HDlink for the conversion from M2T to CF AVI, but eventually I'm going to have to be using Vegas to pull out clips. I also recall, but can't confirm right now, that the results were still similar regardless of what I used to convert, but I will check.
Peter Moore September 2nd, 2005 06:25 PM
Ok, David, you are right - the video is MUCH MUCH better when converted from M2T to AVI using the HDLink tool than when using Vegas.
But here's the problem. At some point I HAVE to use Vegas for the intermediate editing. And I'm going to have to do so using the Cineform codec. Is it just not possible to use Vegas to export cineform files of an acceptable quality level? Will Adobe Premier Pro 1.5 be any better? I have to do _something_.
David Newman September 2nd, 2005 06:46 PM
Peter,
Once the data is in CineForm Intermediate you shouldn't have the problem, even when rendering back out. If there is an issue with exporting to CFHD from Vegas I will look into that. We use a different MPEG decoder within HDLink than Vegas, so maybe that was the difference. I would still like to see that M2T so I can be more detailed in my response.
Connect HD's HDlink is higher quality and significantly faster than Vegas alone, so I don't any good reason not to use it. Could you please explain the steps you are taking in your editing workflow?
Premiere Pro running Aspect HD does have the edge as CineForm developed far more of the components involved, and a lot more YUV processing. Quality is higher as the DirectShow encoder under Aspect HD has more options then the Video for Windows codec used by Vegas. Plus I'm active user of Premiere with Aspect HD, if that counts for anything.
Peter Moore September 2nd, 2005 06:57 PM
Yeah, what I usually do is render clips of no more than 5-10 minutes, then export out, then in a final file put the clips back together to form a long feature. Basically each "act" of the movie is done as a separate project and then combined at the end. It works great in DV because DV doesn't recompress when just cutting. Of course CFHD does, but this shouldn't be too much of an issue.
The quality when exporting from Vegas as opposed to HDLink is indeed very poor IMO. Same thing if I use VirtualDub. I guess this is consistent with what you're saying - HDLink uses a much better process than the VFW codec. I would send you the original M2Ts but I'm afraid they're all rather huge. They just came straight from the tape. I import entire tapes to entire M2T files (I have a massive 1TB array so I don't care about file sizes). I could try Premier, but I don't really want to learn new software for this project. THe only other thing I could do is change my workflow. I think what I might wind up having to do is simply export each clip uncompressed.
Peter Moore September 2nd, 2005 07:02 PM
The other thing I do, btw, is 60i->24p conversion using VirtualDub. Thus, even if I use HDLink to compress to CFHD, I still need to use VirtualDub to re-encode it. VirtualDub only supports VFW codecs as far as I know, so if the VFW CFHD codec is not as good as what HDLink uses, then I cannot use it.
Can't you make the VFW codec just as powerful as the one used in HDLink? I cannot even frameserve to HDLink because it only supports M2T files.
David Newman September 3rd, 2005 10:30 AM
The VfW codec is not THAT much different, so I'm looking for examples that demonstrate a problem. The main difference in using VFW is RGB which doesn't quite have the dynamic range of YUV (particularly within VirtualDub which is cgRGB, unlike Vegas's studioRGB.) Yet if you happy with VirtualDub uncompressed output the CineForm output should match. The only other differences are the VFW codec assumes interlaced encoding for 1080i and progressive 720p (this can't be overridden) and the VFW codec is hard coded to medium quality (which hasn't caused any issue in the past.) I would like to confirm which you are seeing, for that I need your source data and the steps in your workflow (such as the 60i->24p within VirtualDub, and are you resizing also, and with what filter, etc?)
Peter Moore September 3rd, 2005 04:27 PM
Well, we can not worry about all that other stuff. That other stuff is the reason I Need to use Vegas or some other program with VFW to re-compress the footage at some point, but it is not the source of the problem.
In its simplest form, the problem is that M2T data (1080i HDV) straight from the tape looks good when converted to Cineform using HDLink, and looks terrible when converted to Cineform with Vegas using the standard HDV-1080i template. The source material is just too big (multiple gigabytes) to get it to you. But you've seen screenshots. The only other thing that I Can tell you is that the footage is from a Sony Z1. I'm afraid I cannot even copy a tape for you, as I don't have the camera anymore.
I think, and this is just a guess, that Vegas is using a lower qualiy setting on the codec than HDLink. It sure looks that way. Esp. since there's no way to set the quality using the VFW codec (unlike when using HDLink).
Kyle Edwards September 3rd, 2005 04:44 PM
You can cut out a piece of the original M2T without re-encoding and send that file to David. That is what he is asking for so he can recreate your problem. The clip doesn't have to be long, maybe 2-3sec tops.
Peter Moore September 3rd, 2005 04:45 PM
How can I do it without re-encoding? Vegas can't do it.
David Newman September 3rd, 2005 05:12 PM
Most hex editors can do it. Or a tool like http://www.sofotex.com/MiniSplit-download_L16577.html will happy chop up a larger file. Fortunately transport streams can be chopped randomly and the video/audio can still be extracted. I need a segment about 6MB (2Sec).
Peter Moore September 3rd, 2005 05:23 PM
No kidding!? Ok, gimme 10 minutes and I'll get you your clips.
