-   CineForm Software Showcase (https://www.dvinfo.net/forum/cineform-software-showcase/)
-   -   FCP - forced to render on all effects (https://www.dvinfo.net/forum/cineform-software-showcase/497285-fcp-forced-render-all-effects.html)
Justin Lovell June 16th, 2011 08:14 PM
Is it possible to add any effects on a cineform timeline in FCP and NOT have to render?
I added a dissolve using the pen tool / opacity and have to render everything.
Any realtime effects still possible?
thank you,
David Newman June 16th, 2011 08:22 PM
Re: FCP - forced to render on all effects
turn on the RT Enabler.
Cineform Tech Blog Blog Archive Neo3D System Requirements
Justin Lovell June 16th, 2011 08:36 PM
RT is enabled through the system preferences.
When I apply any effect, I get red render bars.
David Newman June 16th, 2011 08:53 PM
Likely means you video doesn't match you timeline settings.
Justin Lovell June 16th, 2011 09:11 PM
Strange. Thanks for pointing that out. I just checked my sequence settings, and I don't see any settings for Cineform listed in my Sequence presets.. any idea why? FCP ver 7.0.3. (though That shouldn't matter). How do install the presets?
Justin Molush June 16th, 2011 10:10 PM
Easy solution - Rip to prores instead.
I dont know if FCP has Cineform presets, Ive never seen any.
David Newman June 16th, 2011 10:17 PM
Preset aren't needed, simply have FCP automatically configure the sequence to match the clip you place on it. If you set it up wrong there is a solution, but that is a question for someone who actually uses a Mac.
Justin Lovell June 16th, 2011 10:20 PM
There are no sequence presets available in FCP that I am aware of.
I simply open FCP
Import my cineform clips
Drag 1 clip onto the timeline
It asks me if I want to convert my sequence to match the clip, I say OK.
However any effect applied require a render.
Surely there must be a solution for this... or a step I'm missing?
David Newman June 16th, 2011 11:59 PM
Talk to support, as that is you need to do.
Anmol Mishra June 19th, 2011 09:54 PM
Justin please update this thread when you get an answer.
Justin Lovell June 19th, 2011 10:32 PM
working on an answer..
I do know that I'm working with 2048 x 856 footage which could be part of the problem.
I have noticed that 1920x1080 can give me orange bars - with really stuttery playback.
2048x856 NEVER gives me orange render bars, and always forces me to render any transitions/effects.
David Newman June 19th, 2011 10:43 PM
FCP-7 doesn't support greater than HD at all well (particularly Cinema Desktop.) The RT modes are set up for standard HD resolutions only.
Craig Davidson June 20th, 2011 10:29 AM
The RT Enabler does not support 2048x856, only the "normal" resolutions: 1280x720, 1920x1080, 2048x1024 and 2048x1152. FCP chokes on the 2K playback, though.
