Strobe effect in converted 1080i footage
I have converted some 1080i footage from a GH2 camera that is affected with a strobe like effect only after conversion to 16:9 SD. Original footage is pefect as is.
I have used HDlink and set conversion to interlaced, and to progressive, and the same result occurs either way. What's up with this? Anyone know the cause? |
Re: Strobe effect in converted 1080i footage
As "strobe like effect" could be a large number of things, please contact support. Send short footage with the issue.
Never mind, ignore this comment, I was mistaken. I'll fill out a ticket. It seemed when changed to black and white the strobing went away, but I was mistaken.
Hi Jeff
i'm going to buy gh2, and i read many post about recording and HDMI out of gh2. if i remember correctly 1080i recording is ingested in a 60i structure also if you choose a different frame rate. check the instructional manual and verify if you must do some pulldown to recover original frame rate. |
Carlo, I found today that the issue is ONLY in playback on my timeline, very strange.
