-   CineForm Software Showcase (https://www.dvinfo.net/forum/cineform-software-showcase/)
-   -   5DMK2 convert question (https://www.dvinfo.net/forum/cineform-software-showcase/495706-5dmk2-convert-question.html)
Murat Engin May 10th, 2011 08:29 AM
Hi DVINFO members,
I am a new member Dvinfo and Neo(HD) Family. I have a question.
1-Canon 5dmk2 files put to After Effects. (direct, cancel the HDLINK convert)
2-AE color bit depth: 16 bpc(edit,fx...etc)
3-Render ( Cineform Avi, RGB+Alpha ,Trillions of color +,Film scan 2, Enable 4:4:4 encoding )
4-result : 4:2:0(8 bit Canon file) to 4:4:4 (12bit CF avi)
Is that correct ?
or
1-Firstly HDLINK convert(4:2:0 to 4:2:2)
Is that?
I'm confused..!
Thank you.
David Newman May 10th, 2011 11:23 AM
Re: 5DMK2 convert question
Neither works like you imagine. You can't get 4:4:4 from a 4:2:0 source, although you can guess at the missing data to smooth out chroma artifacts. The HDLink 4:2:0 to 4:2:2 is doing this type of chroma artifact reduction. When decoded it will optionally do 4:2:2 to 4:4:4 chroma smoothing (if you select "Filter 422 to 444" in the "C" systray control). So HDLink does all you need, there is no gain in baking it all into a new 4:4:4 file which is twice as big without twice the information. If you go with you first approach, using CS directly, where is your 4:2:0 to 4:4:4 interpolation occurring? Short of add filters, AE or PPro makes no attempt to fixing chroma 4:2:0 artifacts, so you would end up baking the artifacts into a large 4:4:4 file -- zero gain, backwards step.
Murat Engin May 10th, 2011 12:17 PM
Thanks ....
1-
2-
3-
4-
please...
Martin Guitar May 10th, 2011 12:45 PM
1. Drag and drop your 5D files into HDLink for conversion
2. Done.
