Cineform Won't Export Via AME
Running the latest releases of CS5 and Neo4K.
Decided to give the latest Cineform Beta a try.... and without paying attention, I downloaded and installed Neo, not Neo4K. Is there even a difference now? In any event, at about this time... or perhaps because of my possible error, Premiere will not export a Cineform encode request to Media Encoder. It does so with any other format, so this is a Cineform exclusive issue so far as I can determine. I have subsequently downloaded and installed the most recent Neo4K I could get (5.3.2 Build 302), and installed and seems to function with my original license key intact which I did not remove as part of the uninstall prior to my update, but the export issue with Premiere remains. Attempted to submit a ticket, but my log in info is not accepted at the Cineform site..... I'm thinking this might NOT be the day for me to invest in a Lottery Ticket. Any words of advice out there? |
Re: Cineform Won't Export Via AME
On the Cineform site, you have to register as a new user. Your old username/pw does not work after they changed their site. (you can use the same username/pw when you register again)
thanks Trond... I'm in.
Hope to get a solution to my export issue. |
