Screen Flashing with Premiere Pro CS5
I have a project with both regular sequences and Cineform sequences. I have a Cineform sequence selected and then select a non-Cineform sequence, the entire screen flashes. The same thing happens when going from a non-Cineform sequence to a Cineform sequence.
I assume it has something to do with 10bit as I use a Quadro FX3800 with DisplayPort to a 10bit LCD (Eizo CG243W) on Windows 7 x64 because the exact same thing happens every time I open a project in Premiere. Is Cineform compatible with Premiere's 10bit output? Thanks |
Re: Screen Flashing with Premiere Pro CS5
Does anyone know the answer?
Is any part of Cineform software compatible with 10bit outputs such as FirstLight or through Premiere Pro? |
