-   CineForm Software Showcase (https://www.dvinfo.net/forum/cineform-software-showcase/)
-   -   Vegas 10.0c and Cineform (https://www.dvinfo.net/forum/cineform-software-showcase/492190-vegas-10-0c-cineform.html)
Marc Salvatore February 23rd, 2011 07:36 PM
I just installed Vegas 10 and I'm using Neo HD 5 (latest version). I noticed that the export settings for Cineform from within Vegas are much more limited now. You no longer have the option for interlaced/progressive, aspect ratio, hd colorspace etc. All that is available is: Encoded format and encode quality (no higher HD setting).
Is this normal for Vegas 10 due to the changes in the sdk or has Sony not completed the features?
Thank you, Marc
David Newman February 23rd, 2011 08:57 PM
Re: Vegas 10.0c and Cineform
As Sony in now in control of that GUI, I can;t confirm, yet the other features are likely controlled by the project settings (such as interlaced vs progressive.)
Marc Salvatore February 24th, 2011 01:05 PM
I now have two options when clicking configure in Vegas.
1. Encoded format: YUV 4:2:2, RGB 4:4:4, RGBA 4:4:4 (which one should I choose?)
2. Encoding quality (Higher HD is no longer an option)
Also I used to have the option of Decode/encode controls (ITU.Bt.709 (HD ) colorspace etc.) which are no longer available. Should I be concerned about this?
Thanks, Marc
David Newman February 24th, 2011 01:15 PM
1. You are only licensed for 4:2:2 with NeoHD.
2. "Higher" was the same as "High" but for special case with handling noisy/highly textured source, this was before there was Filmscan mode. No longer need "Higher".
If you are concern about colorspace, that is question for Sony. I'm assuming they are setting all the correct flags to match the colorspace of the project settings.
Marc Salvatore February 24th, 2011 01:31 PM
Thank you. Just so you know at present the 4:4:4 options are available and I'm able to render them.
David Newman February 24th, 2011 01:47 PM
I know, and you get a watermark if you use them without Neo4K or Neo3D.
