HDLINK - Sharing Violation has occured
I have si2k footage on my "y:\" drive (4 drives raided together). I am running HD link off my "c:/" drive. If I try to transcode a file that is on the Y:\ drive, I get a sharing violation, and it does not allow me to render the file. If the File is on my C:\ drive, it works.
Any fix for this? I have some LARGE files I need to get converted, and will take some time to move them all over. Thanks! |
I expect there is something you have set up wrong. I have had so many configurations of drives and RAIDs, never once had a sharing violation converting with HDLink.
something setup wrong like what?
do you have seven?
seven is a master of confusion about right of read write on file, disk and more... verify that your user are allowed to write on disk Y, try to write in a new folder created from your user. eventually there is a free utility called takeownership to be the owner of your files... i would like to live in a world where XP64 come back to the power, less problem more speed... :-( |
i have windows 7.
i can read and write to the drives with everyother software, except with hdlink... maybe some permissions setting in HDlink is not working with windows 7 64bit. |
I'm running Win 7 and with no issues. Nor have I heard on this from other customers, so it has to be local configuration issue, I just don't know what.
| All times are GMT -6. The time now is 04:15 PM. |
