-   CineForm Software Showcase (https://www.dvinfo.net/forum/cineform-software-showcase/)
-   -   Cineform AVI can be loaed into any MPEG 2 Encoder? (https://www.dvinfo.net/forum/cineform-software-showcase/48823-cineform-avi-can-loaed-into-any-mpeg-2-encoder.html)
Greg Jacobson August 4th, 2005 11:41 AM
What if I want to use a different MPEG 2 encoder instead of the Main Concept encoder inside of Premiere Pro. Can I just output a Cineform AVI and then load that into a program like CinemaCraft or Procoder?
David Newman August 4th, 2005 12:28 PM
Generally yes, CineForm AVI files can be loaded into any Windows tool for encoding into MPEG2 or any other export format.
Randy Donato August 4th, 2005 01:27 PM
If you have Procoder 2 it plugs into PPro and works fine with CFHD. Be sure that upper fields is selected and 16:9 with a pixel aspect of 4:3 is used and it makes great mpegs. If you have Procoder express then you will have to run it standalone and use a single file. The main Concept encoder is very limited compared to procoder.
