HD LINK improvement- to know which clips are 24/60 before transcoding
When Importing clips, it would be helpful to see the frame rate / resolution.
Remaster has this information available, so does Final Cut pro Log and Transfer. I have a bulk of footage, mixed onto one drive of 720p 60 and 1080i 24p from a GH1. I have not found a quick way on a PC to see the file information to know which clips are which resolution. (as a workaround, I open the clips on a mac to get the file info, then write that all down). |
Having that info available in HD Link would be pretty nice. I'll second that suggestion.
If you're on a Windows machine and you're dealing with Quicktime files, you can open each file in Quicktime Player and see all the specs in Inspector. With AVIs I use VLC. VLC can't open everything (Cineform files won't play in VLC) but most common AVI, WMV and FLV flavors will. For those not-so-common flavors, the only way to see the specs are to pull them into your editor. All that is a real pain in the butt. Having the specs available right when you pull it into HD Link would speed up some of the decision making. |
| All times are GMT -6. The time now is 06:00 PM. |
