-   CineForm Software Showcase (https://www.dvinfo.net/forum/cineform-software-showcase/)
-   -   Converting Canon 5D mark ii 24p material - NeoScene unable to detect frame rate (https://www.dvinfo.net/forum/cineform-software-showcase/484484-converting-canon-5d-mark-ii-24p-material-neoscene-unable-detect-frame-rate.html)
Adi Head September 9th, 2010 05:01 AM
Hi.
I've just started out using Cineform, testing it out with a trial version of NeoScene I downloaded a few days ago.
I'm shooting with a Canon 5D mark ii and converting the files with NeoScene to Cineform-coded avi files for editing (I'm in PAL land, running Windows XP).
I've managed to shoot 1080 (25p) and convert successfully.
Then I tried to shooting with the Canon 5D mark ii set to 1080 (24p).
When attempting to convert the 24p - I got the following notifications in the CineForm Capture/Convert Log:
- Unable to determine frame rate. Default to 29.97 fps
- No audio stream found
As for the frame rate issue:
In NeoScene Prefs > Output frame format > I had "Maintain source frame format" and "Progressive Source" both checked.
Regarding the audio stream:
Didn't run into this problem with 25p. Also, I checked the original .mov file that I imported from the camera and it definitely has sound.
Any ideas why this is happening?
THX
Jake Segraves September 9th, 2010 10:45 AM
Installing the latest QuickTime Player will usually solve this.
Adi Head September 9th, 2010 09:26 PM
Indeed it did!
Thanks.
