Cineform captured files not fully showing in CS4
1 Attachment(s)
Any video footage captured with NeoHD doesn't fully show in CS4.
For example, I captured 45 minutes of film and can view all of it in Windows Media, but when I import into CS4 I can only view 1 minute of it. Everything was working fine when i used ver 5.1.0, but after I installed 5.1.1 the problem started. Even though i've uninstalled 5.1.1 and installed 5.10, the problem is still there which means I can't do any work work on my projects. There are no problems capturing with CS4. Attached is a screen shot of the options I use. Anyone know what the problem could be? (I submitted a support ticket on monday but have not received a response and I need to upload the files asap.) |
Hello,
When you say you can only view 1min of the footage in Adobe Premiere Pro cs4, can you explain what happens? Leo |
This has been solved, and a patch is available for 5.1.1 and 5.1.2. It will be fixed in 5.1.3.
You need a new CS4 importer - http://www.cineform.com/downloads/CFHD_AVI_Importer.zip Unzip and replace in C:\Program Files (x86)\Adobe\Common\Plug-ins\CS4\MediaCore\CineForm C:\Program Files (x86)\Adobe\Adobe Premiere Pro CS4\Plug-ins\Common\CineForm |
Now I have the same problem with Adobe media encoder.
From a 6 minute video, I can only encode 6 seconds. Is there a patch for that as well? |
The beta with the importer patch is going out in a few minutes.
Turns out the media encoder issue was not a problem caused by cineform software.
Thanks for your help. Everything working fine now. |
