first light in cs5
I just have installed my new CS5 bundle with the quadro fx 3800 if i start a cineform project and when i apply and effect from first light then the playback is not smooth and i can see at performance that my cpu's goes sometimes up to 100%.
If i do the same in CS3 it does not have these issues and playback is good cpu's only about 25% Also if i put more files on my timeline and put a title on top when i render it out it gives this error R6025 pure virtual function call then my adobe premiere CS5 does not start up no more i have to restart my computer before i can use premiere again. Can anyone help me please Rudy |
The "R6025 pure virtual" is an Adobe bug, that Adobe has instructed us on how to work work, the build will be up today.
CS3 defaults to half res playback, you can do the same in CS5 for more performance. |
I tested now the cineform files in a XDCAM EX project and then it seem they play smoother and i do not have the error but i'm not sure if it is the right workflow is it okay if i just use xdcam project?
Rudy, what you are experiencing sounds similar to this:
http://www.dvinfo.net/forum/cineform...miere-cs5.html |
I film with sony xd ex1 and edit with cineform many years now in cs5 I tried also native in a xd project and till now it works great .
What is the benefit with cineform? System: Windows vista ultimate 64 bit service pack 2 Processor: Dual intel Xeon CPU 5140 2.33 (2 processors) makes 4 cores Memory: 14 GB Display adapter: NVIDIA Quadro FX 3800 Boot drive: 10.000rpm AV drive: 2 times 250GB 7200rpm in raid 0 |
| All times are GMT -6. The time now is 05:46 AM. |
