-   CineForm Software Showcase (https://www.dvinfo.net/forum/cineform-software-showcase/)
-   -   New Peak Files Every Time (https://www.dvinfo.net/forum/cineform-software-showcase/480332-new-peak-files-every-time.html)
Lloyd Coleman June 13th, 2010 03:03 PM
Each time I open a Premiere CS5 project it generates new peak files, even though it generated them the last time the project was opened. This appears to only happen with Cineform files.
When I look in the folder where the peak files are stored I see a new version of the file for each instance I have opened the project, for example:
filename.pek
filename_1.pek
filename_2.pek
filename_3.pek
This is only happening with Cineform converted files. I have tried it with files converted from a Canon 7D (h.264 files) and XH A1 (m2t files). The original un-converted files don't have the problem (peak files are only generated one time). I am using Neo 4k, although it happens with Cineform files I generated from Prospect HD also.
Any ideas how to fix this?
Thanks, Lloyd
Paul Curtis June 14th, 2010 03:33 AM
I see this too, but it's not *all* my cineform files just some of them. It does make me wonder whether some of the issues i've been seeing are sound related.
i've noticed in PPro that AIF files are not as robust as WAV. With AIF i see it using the wrong parts of a sound file sometimes, so far this hasn't happened in WAV
cheers
paul
Don Blish June 14th, 2010 09:42 AM
New .pek files...
I have noticed this on my latest project, and I am still on CS4 and ProspectHD. Since it is just a few at a time, I suspect these are for files that on the previous session I dropped audio tools on like hipass and lowpass, in which case it would be understandable.
Graham Hickling June 14th, 2010 12:59 PM
I'm seeing this too, again just with some CFHD files (but quite a few of them). This is with a fresh 720P60 project started in CS5, using avis from an HMC40 converted using Neo4K.
Hans van Enkhuijzen June 14th, 2010 01:55 PM
regenerating pek files
Yes, I have that problem to. It seems related to HD link converted files. I suspect it is a bug of the latest updated HD link.
I am waiting on answers from cineform.
Paul Curtis June 14th, 2010 02:25 PM
Yes, come to think of it i think the files re-peaking are ones i've transcoded again with the new HD Link, so that could well be the culprit
cheers
paul
Hans van Enkhuijzen June 15th, 2010 11:47 AM
Just got an email from cineform as follows;
David Newman knows about it and has been in contact with adobe. Adobe says this happens when the modified date of the avi files changes. The problem is, that Premiere is the culprit in changing this date! So David is trying to figure out what to do about it.
Paul Curtis June 15th, 2010 12:10 PM
If PPro is the culprit why only some cineform files and not all of them (and non cineform)? I imagine perhaps cineform is updating the meta information in their files, causing the reload? Guessing here though...
cheers
paul
David Newman June 15th, 2010 12:21 PM
While I said that internally and neeeded to confirm, it wasn't to go out -- we do not modify the files, yet Premiere has in the past for their metadata.
Paul,
We do not modify the files for metadata, that happens external to the AVI or MOV wrapped data.
Brian Tori June 15th, 2010 01:18 PM
It's definitely a Premiere issue. I've had this problem since CS3 and now with CS4. It seems to always happen if the external drive with the project is moved from machine A to machine B. Even if the drive letter is constant. Very annoying.
Rich Perry June 16th, 2010 02:32 AM
I have the same issue with CS5, worked with adobe for 2 weeks and tried every solution they threw at me. I still have just a few of the same files that keep regenerating within a project, I have no ideas whats causing this with just certain files, I only use cineform files so I can't compare. Actually thinking about it - it's only recent files encoded within the last month via HDlink, not sure if it's all files or just a few of the recent files.
Hans van Enkhuijzen June 17th, 2010 01:40 PM
With the new update 5.04 problem is solved. Just import your 5.03 converted files in a new project and..done
No regenerating files anymore.
Thank you Cineform for this quick fix !!
Regards Hans
Lloyd Coleman June 18th, 2010 12:53 AM
Hans,
I've updated and still get peak files generated each time I open the project. Is there anything else that you might have done besides the update?
Lloyd
Hans van Enkhuijzen June 18th, 2010 10:26 AM
Hi Lloyd,
Delete al the pek and other media cache files, including all other reference junk of your previous project also in the user application data/roaming/adobe and common map. Start a new project and import the AVI files in the new project. For your new project store the media files in the same project map as the project. You can do this by opening preferences and than check media. This was my approach and hope this will help you to.
Rgrds Hans
John Rich June 21st, 2010 10:45 AM
Hans,
I appologize for the elementary questions, but I just updated to w7 from xp.
Am I correct in saying that
1. Create a main project file for audio, premiere project, video etc.
2. In the Premier Project file (where I originally set the path for the project when it opens) I go to Edit Preverences - Media and
3. Change the location of the Media Casche Files and the Media Cache Data base to the Premiere Project file so these files are all together with the Project file.
4. Then when I update to Cineform 5.04, the Peak files won't be regenerated each time I open the project?
By the way I'm using CS5 here.
Thanks in advance,
John Rich
