Neoscene question: what option to choose re: frame rate w/ 5D Mark II recording @ 24p
Hi,
Simple question with hopefully a simple answer: with the updated firmware for the Canon 5DMII I now record @ 24fps. When using Neoscene, should I select "leave source frame rate" (not sure of actual text), or "convert to 24p"? TIA, Per |
"leave source frame rate" is the correct setting (although the other shouldn't do anything with a 24p source.)
Cheers, David!
