XDCAM EX 25P tp 23.976P with HDLink = Audio Problem.
Hello.
I did a conversion from EX3 clips 1920x1080 25p to 1920x1080 23.976p using HDLink. Everything seems fine. BUT on a longer clip, I'm missing the audio halfway to the end. For example: a 14 mins clip after converted to CFHD using HDLink, everything is fine (audio+video) untill around 10mins something all of a sudden no audio anymore (video only). I remember I used to have another audio problem when converting EX clips using HDLink with "Rate Change" feature. Then I solved it by first converting EX clips to MXF files in ClipBrowser, then take the mxf files to HDLink to go from 25P to 23.976P with a success. UNFORTUNATELY, HDLink now doesn't recognize mxf files anymore. Please any comments?? Thanks in advance. |
Seriously... nobody else having this problem when converting EX Clips 25P to Cineform Avi 23.976P using HDLink?
| All times are GMT -6. The time now is 03:22 PM. |
