-   CineForm Software Showcase (https://www.dvinfo.net/forum/cineform-software-showcase/)
-   -   Cineform/Premiere Audio (https://www.dvinfo.net/forum/cineform-software-showcase/473414-cineform-premiere-audio.html)
Marc de Jesus February 23rd, 2010 03:16 AM
I'm working on an I7 920, Win 7ult64, 12g ram, fx3800 machine with Prospecthd and premierecs3.
While playing back real time on the timeline, i get random skips in the audio from time to time, basically not smooth playback unlike the smooth audio playback I get from my Powermac running FCP at work.
Is this a result of using the onboard audio from my Asus mobo?? Should I buy a seperate audio card to ensure smooth audio playback??? If so, which card would be recommended?
Thanks for any help! Appreciate all the advice i'm getting here.
Rich Perry February 23rd, 2010 06:59 PM
Hi Marc - This issue goes back quite a while (2 years) with certain combinations of hardware. I have almost the same system, win7 cs3, with exception of an FX4800 and i960 with Asus mobo. I recently built this new system and just started editing on it today but now finding the dreaded audio skipping issue cropping up again and I happened to see your post.
The fix in the past was to use a different audio driver (asio4all)
See: ASIO4ALL - Universal ASIO Driver Then cineform fixed it in a prior release and the asio4all driver was not required. At this point the asio4all is not working for me anyway and I am experiencing audio pops and skipping on the timeline. I have disabled my onboard soundcard as I am using USB speakers which worked fine with my previous Abit mobo and Vista 64. I will play around with some more configurations to try and find a cure.
Marc de Jesus February 24th, 2010 01:53 AM
btw, im using an asus mobo as well, the p6 deluxe
Marc de Jesus February 24th, 2010 01:55 AM
Hey Rich thanks for the response. I'm assuming though, that the pops and skips dont show up when exported out right?? I have yet to master, so thats why im asking.
So even if I got an audio card, that probably wouldnt make a difference? Anyway, good luck with trying to find a solution.. if it doesnt affect the final exported master, then it will just be an annoyance i will have to live with...
oh wait, are you not getting these pops with the usb speakers?? if not than, i may just go that route for the time being.
Rich Perry February 24th, 2010 05:35 AM
interesting, your mobo is the same chipset as mine, LGA1366 (X58). I read some older threads recently with audio issues and asus mobo problems. Anyway, exporting seems fine, no glitches. CS3 works better with the new 2.10 version of ASIO4ALL, but there are still pops and skips on timeline playback which is annoying.
I tried USB speakers, disabling on board sound as well as taking a standard audio signal direct from the motherboard but it doesn't matter what I do. I am thinking a seperate sound card will make no difference. So far I am unable to duplicate this issue using CS3 templates only in cineform templates, I will have to open a cineform ticket on this.
Marc de Jesus February 24th, 2010 09:54 AM
earlier today i cut together footage from my 5dmkii to an .mp3 track and got audio sync issues. it seems that there was a delay between the sound and what actually was playing on the monitor anytime i played live from the timeline. which of course, isn't good, because im trying to time the cuts to the beats of the track. after 4 attempts of editing, exporting and viewing, im finally uploading it to vimeo rite now, to see if the export is truly in sync.
i actually opened up a ticket on this earlier today, so hopefully they have a reliable solution, otherwise, editing will get annoying. if i hear anything noteworthy i'll keep u posted
Rich Perry February 24th, 2010 02:29 PM
I exported a short 30 sec sequence with about 12 clips, sequenced to an audio track,
initial results seem the video us lagging behind possibly because I cranked the audio buffers in the ASIO4ALL driver (To stop the skipping) and my timline my not be accurately synced due to the large buffers. I have a cineform ticket open also, sounds like the same set of issues.
Marc de Jesus February 26th, 2010 09:46 PM
Hey Rich,
Dunno if this helps, but, after a quick test, premiere cs4 seemed to be spot on with some quick cuts to audio beats and significant reduction in the skips/pops. but then again, this came after spending just 30 minutes on premiere cs4. btw, used cs3 to capture the clips.
Rich Perry February 26th, 2010 09:49 PM
Thanks for the update Marc, I think its something to do with the audio buffers in CS3 and the asus mobo, it's better with the ASIO4ALL driver but still glitchy. I still have a cineform ticket open, no problems when using premier templates without cineform however. I don't have a license for CS4, I figured with so many issues I would wait for CS5 to arrive, it would be nice to get the audio sorted out but in the mean time I will have to hobble along.
Marc de Jesus February 27th, 2010 12:13 AM
Oh yah, on my ticket they recommended "go to cineform folder in the windows start menu and in the tools folder, click on the option that says 'desktop playback - fast'." I dunno if u've already done that or if it would even help ure situation.
I was gonna wait till CS5 too, but able to get a pretty good deal on the student edition of produciton premium (not bad for taking a tennis class lol).
