-   CineForm Software Showcase (https://www.dvinfo.net/forum/cineform-software-showcase/)
-   -   (Likely) Last PC releases for 2009 (https://www.dvinfo.net/forum/cineform-software-showcase/469948-likely-last-pc-releases-2009-a.html)
David Newman December 23rd, 2009 07:28 PM
While no new features in this relase, there are some handy bug fixes in v4.1.6.
From the readme:
Fixes: for codec compatibility with some Window 7 systems running 64-bit codecs.
-- this was causing Vegas and other VFW tools to sometime not see the decoder.
Fixes: for CS3 playback under Windows 7.
-- no more upside-down pink playback in Prospect CS3/Win7. Gaps play correctly also.
Fixes: First Light now handle 25Hz timecode correctly.
-- First Light was only doing 24 and 30 base timecode, now it also does 25.
Download links for trials and updates.
Prospect 3D http://www.cineform.com/downloads/Pr...233-091223.zip
Prospect 4K http://www.cineform.com/downloads/Pr...233-091223.zip
Prospect HD http://www.cineform.com/downloads/Pr...233-091223.zip
Neo 3D http://www.cineform.com/downloads/Ne...233-091223.zip
Neo 4K http://www.cineform.com/downloads/Ne...233-091223.zip
Neo HD http://www.cineform.com/downloads/Ne...233-091223.zip
NeoScene http://www.cineform.com/downloads/Ne...133-091223.zip
Bob Hart December 23rd, 2009 09:06 PM
David.
All the best for Christmas and New Year to you and your own up there in the country where the seasons are wrongway round.
Graham Hickling December 24th, 2009 12:27 AM
Thanks for the Win7/CS3 fix - nice Xmas present!
In today's PHD4 build (416b233) superwhites are still not displaying in PPro's YC Waveform display .... whereas they do display when I use 413b227.
This is repeatable - the superwhite display comes and goes as I swop back and forth between the two builds.
I'm seeing the problem with today's build in both PPro CS4.1 and 4.2 .... however in CS3 it is displaying correctly.
David Newman December 24th, 2009 10:00 AM
This might be only an instrumentation failure, and therefore cosmetic, but I do need to determine if it is. If Premiere asks for the wrong pixel format for rendering the YC Waveform, is will have no ability to know anything above 100% even if is it there. Under CS3 will control this, under CS4 it is (more) Adobe. We never clamp YUV requests, but often Premiere requests 8-bit RGB, limiting scope rendering to 100%.
David Newman December 24th, 2009 07:44 PM
The NeoScene link was mis-named
Brant Gajda December 25th, 2009 07:37 AM
Thanks David. Downloading the NeoScene now.
Geoff Gartside December 28th, 2009 10:11 AM
Seasons' Greetings!
This update solves a problem I had with PPro import server crash (happened when FL Histogram was enabled). Now I have histogram and premiere. Thanks.
