v4.13 Build 228
I just up graded to the current version from : v4.08 Build 217. I think? I was excited about the additions to firstlight! Audio export was perfect. Now with 4.04 audio is now way out of sync. Audio play fine in the time line but after render it is way out of sync..
Using CS3 vista 64 Any Ideas |
Don't know if it'll solve your particular problem but there's a beta available that is a newer build:
http://www.dvinfo.net/forum/cineform...a-release.html and then a bug fix for that beta (haven't yet had a chance to verify that the bug fix did the trick): http://www.dvinfo.net/forum/cineform...-properly.html Uninstall b228 first, then install b230 and do the copy-and-paste for the bug fix. If that doesn't help, definitely file a trouble ticket with Cineform at their web site. Let us know how things go. |
Hi Dave I was hoping you would have a comment? Has anyone else had this issue?
We've had a couple of reports on DVInfo only, yet no one has uploaded anything we can use to confirm. Need a sample from the field so we can determine if there is a bug. I don't believe we have change anything regarding audio handling.
David, I have a support ticket filed with an audio sync issue and a file uploaded to yousendit that I sent on Friday
Sorry, that hasn't got to me yet, I will ask Jake. Thanks.
Thanks David,
I just updated the ticket with some interesting new info....very wierd. |
I'm not in support, so I don't see the ticket info directly.
ok i'll sum it up
this is all related to clips rendered from AE Rendered using the render queue...and using the CIneformAVI output...not VFW the clips i sent to jake, played out of sync in PPRO without fail ON THE DAY THEY WERE CREATED (i could reproduce it every thime i rendered a clip from AE) they now, a few days later, playback fine on my system within PPRO with no issues when i render the SAME clips TODAY with the same source files and settings today they ARE ALL OUT OF SYNC AGAIN This is irregardless of the source....I just tested with an DVCProHD clip, a clip from RED, and a cineform express clip from RED. the wierd thing is that the same clips i produced before that were 100% out of sync on friday....now play back 100% in sync..... i have no way of knowing what is going on but it really seems like the clips play out of sync on there creation date...or some set period of time after there creation...maybe tied to active metadata or something sorry if i'm hijacking this thread edit:disregard...the old clips are OUT OF SYNC AGAIN....they were fine for an hour or so...until I restarted.....i'm gonna stop speculating and leading you guys on a wild goose chase...sorry |
Ok that is all pretty weird. AE is doing something to the audio to mess-up to offset when read by the Premiere AVI importer. Could not see anything wrong.
Workaround: Load the AE AVI exports into VirtualDub, set both video and audio to "Direct stream copy" mode then save a new AVI (this is fast and lossless.) The VirtualDub AVI engine is more modern than AE's (by about 10 years) and the audio will then come in to Premiere fine. |
If sync or speed are affected by a restart, I would start with your audio drivers.
It is an importer issue, as the waveform is impacted. Very weird.
my studio has 4 different computers all with different configs and theres no escaping it |
David...you guys have it on your radar which makes me happy...
the virtualdub fix is a good workaround for now being that it is lossless |
Dave do you have a work around for PPCs3? I have a project created and captured with Ver 228 exports perfect. When I install 4.13 from CF site when I export to CF master audio is out of sync? I did the update because I wanted to use the new features of Firstlight. When I uninstall and go back to old version it exports fine?
| All times are GMT -6. The time now is 05:22 PM. |
