-   CineForm Software Showcase (https://www.dvinfo.net/forum/cineform-software-showcase/)
-   -   "Failed to Build Graph" exporting 7D footage out of AE (https://www.dvinfo.net/forum/cineform-software-showcase/468868-failed-build-graph-exporting-7d-footage-out-ae.html)
Stephen van Vuuren December 3rd, 2009 03:54 PM
I have 7D footage converted with Cineform. AE identifies it as 1920 X 1080 with trillions of colors. I imported into 16-bit project.
I cannot render out with getting a failed render with log "After Effects Error: Failed to Build Graph". Even if I turn off all effects and just try a plain export, same error. Changing frame size etc. to smaller, same error.
Under Output modules, "Cineform AVI" is listed - this one defaults to "Trillions of Colors+" or ""Millions of Colors+". Both fail. The Cineform Encoder is not the VfW one under settings.
Windows AVI has a Cineform option that gives the VfW - however, "Trillions of Colors" or ""Trillions of Colors+" is not available and I don't want to go down to a 8-bit file.
Tried uinstalling and installing the new version. No change.
David Newman December 3rd, 2009 05:02 PM
For support, file a ticket here Support Center
Clearly something is not installed. Tell support the versions of all products involved (AE, OS, CineForm etc.)
Stephen van Vuuren December 3rd, 2009 05:05 PM
Okay - one is filed. I put the info all in.
