Firstlight contrast not working
If I use firstlight everything works good except the contrast in the window of firstlight self it is working but as soon as I apply it and go to cs3 the file is almost black.I tested this with the last beta but also with the previous one both have this problem.
Please help Thanks Rudy |
1 Attachment(s)
Please report as soon as you find a thing like that, as they aren't typically easy to fix. I have just confirmed.
But there is a workaround. Unzip the attachment and double click on the one2one.look file. That will register this do nothing look. The contrast problem in CS3 only occur with the look off. So add the one2one look and the contrast will work. |
Hi David
Thanks it works fine now. At the moment I'm using the new beta everything is working fine so far. thanks Rudy |
