I am not off to a good start, I cant install Neoscene
I got lost on step #4 = Windows System Code. The Q & A area states:
Q: Where do you find your Windows System Code (sometimes called "Hardware Fingerprint")? A: Run the Activate.exe utility found in the CineForm folder under Windows Start Menu. (You might need to click "Enter Key"). Note: If you see TWO fingerprints, use the one labelled "enh". To be blunt, I cant find the Activate.exe utility found in the CineForm folder. Can anyone give me an answer on how to install this software? |
1 Attachment(s)
Maybe a picture will help.
Also when you launch the trial of Neo Scene, that too will give a button for "Activate". |
^^^When I highlight or click on the Cineform icon as you show there are no files there & specifically, no activate option. In other words the path goes programs to cineform & ends there.
Reinstall Neo Scene. Then check the start menu folder again.
^^^^ Jake, I got it installed & feel like I lost a couple of IQ points in the process. Nothing like installing a simple software program to humble me. Thanks for your help!
| All times are GMT -6. The time now is 09:12 AM. |
