Neo Scene is choppy in CS4 with Magic Bullet Looks
I just started using Neo Scene with CS4 and noticed it had very smooth previews in 1080p. I'm using a 5D2 and this seemed like my best option until I applied some color grading with Magic Bullet Looks. The previews became very choppy as soon as I applied some effects and even after replacing the 1080p files with 320p proxies, the previews were almost just as slow. The only way to get smooth playback is to render the timeline, but that is a bit too tedious and defeats the purpose of using Neo Scene. I'm just wondering if I had done something wrong to get such choppy previews with minor effects.
I used to transcode my footage to mpeg2 and they were quite smooth in CS4 even with lots of effects applied, I didn't need to render anything. Any help would be appreciated. my specs: Intel Q9550 @ 3.4 Ghz 8GB DDR2 1066 2 x Western Digital Caviar Black 1TB Geforce 9800 GTX+ |
In my experience, Magic Bullet looks, brilliant though it is, is scarcely minor colour correction. I'd be very pleased but very surprised if I could get real-time playback with a look applied on HD material. But maybe I'm unlucky, too...
Ian |
While it is more pricey, try Neo HD with First Light you can apply looks without rendering. We haven't found any faster way to do than have the codec itself apply color correction before presenting the image to the NLE.
Thanks for the insight David, I wish I did more research about the differences before I purchased Neo Scene. I've read that native 5D2 h264 files with 320p proxies have been quite successful, but didn't understand why it was so slow with Neo Scene proxies? I normally work in 720p projects and the playback with mpeg2s were much smoother than the 320p proxies I'm trying to use.
The only way I can think of to make this work is to use proxies without the Neo Scene codec, but I'm afraid that when I relink my HD media back, the color won't be exactly what I expected due to the higher color profile in Neo Scene video files. could someone correct me if I'm wrong? |
Where are you creating 320p proxies? There is no reason these would be slow.
I used Adobe Media Encoder to resize the 1080p Cineform avis into 320p Microsoft AVI with CineForm HD codec. Is it bad to transcode CineForm into CineForm again? I have been deleting my native h264 files after converting them into CineForm avis with Neo Scene (not AMC). I probably should have kept my original files, but since CineForm is much superior, I thought it would be unnecessary.
That will work, just slower than Neo HD's HDLink scaling. Why 320p (??? x 320)? Maybe you are forcing CS4 to do weird scaling, and that is why it is slow. Make sure you sequence resolution is the same as your proxy resolution, otherwise you have saved nothing (Premiere will scale the source up before the filter, meaning your filter are still running 1080p.)
Im totally sorry about the 320p, I actually had 640 x 360, my math skills are horrible now..
I just did some tests and it seems that certain effects such as film grain and diffusion use up a lot of resources for previews and turning those off seemed to make even my 1080p previews super smooth again. I can live with this since film grain and diffusion can be applied to the whole video after it's cut. CineForm definitely wasn't the bottleneck in this case and I think it was either my system or MB Looks which was not working efficiently. thank you for the help David |
If you are using certain nVidia cards, the graphic card will participate in the rendering and speed things up. ATI card will not help, last I looked anyway. If you can get the look you want with Firstlight, that's the way to go. It's like free lunch. I hardly use any other CC tools anymore for routine editing. P.S. David Newman- off topic, but a wierd Firstlight thing: if I turn the histogram on in FL, then the histogram will show up in all CS4 CF timeline previews, even tho none of the clips were ever imported to FL, and FL is not open. It then causes an Import Proc Server.exe crash & CS4 closes. Open FL, turn histogram off, and everything is back to normal. Is it just me?? |
Magic Bullet Looks supports a wide range of cards from both ATI or NVIDIA:-)
Regards Mikael |
http://www.dvinfo.net/forum/digital-...eleration.html Where might one find a list of these supported cards? Edit: Actually I just checked and the Colorista documentation says that 'supported' ATI cards are '9600XT or better, and X-series beginning at X700'. But they go on to say that Nvidia cards are generally faster than ATI cards of the same level ... so it seems some 'supported' ATI cards may not provide much acceleration. |
As an alternative to MBL, you might want to look at Video Copilot's Film Magic Pro...
VIDEO COPILOT | After Effects Tutorials & Post Production Tools |
| All times are GMT -6. The time now is 04:13 PM. |
