-   CineForm Software Showcase (https://www.dvinfo.net/forum/cineform-software-showcase/)
-   -   Having trouble downconverting with HDLink (https://www.dvinfo.net/forum/cineform-software-showcase/310209-having-trouble-downconverting-hdlink.html)
Marc Salvatore August 22nd, 2009 07:30 PM
I have a progressive 1920x1080 Cineform file that was exported out of Vegas 9.0a.
I bring the file into HD link using the select function in the Convert tab. I set my preferences to resize the file to NTSC 16:9. I click on start and a little red X appears to the left of the file name. The progress bar never moves and the computer does not show any CPU use.
Am I missing something here?
Thank you, Marc
Marc Salvatore August 22nd, 2009 10:36 PM
I figured out the problem. I did not have the "use capture location for converted files" checked. It works now.
Another question. Can I use HDLink to deinterlace during downconversions?
Andy Urtusuastegui August 23rd, 2009 05:10 PM
Yes it can. There is a check box you need select and choose progressive as the frame type.
