-   CineForm Software Showcase (https://www.dvinfo.net/forum/cineform-software-showcase/)
-   -   Help with NeoScene on a dual boot system (https://www.dvinfo.net/forum/cineform-software-showcase/285071-help-neoscene-dual-boot-system.html)
Paul Cascio August 16th, 2009 07:58 AM
I'm currently testing Win7, on which NeoScene is installed. Will NS also install on my XP partition with no problem, and without counting as a 2nd installation, so I can keep it on my laptop?
Pete Bauer August 16th, 2009 10:16 AM
Pending the Cineform guys weighing in, I'd assume that you can install it fine but each installation on a unique partition/OS will take a separate activation. You can always give it a try; if the activation is allowed on the test partition, just de-activate when you're finished trying it. Let us know how it goes!
Graham Hickling August 17th, 2009 05:55 PM
Yes, Cineform products install fine on dual partitions - but NeoScene will generate a different hardware code for each partition, so two authorizations will be needed.
