Getting watermarks in FCP with titles etc.
Hi,
just switched over to FC from PP so it is probably me ... but, when I add titles, or non-Cineform stock footage into my Final Cut project, I'm getting Cineform's logos as watermarks in the 4 corners. Why? I'm not encoding, I don't think. I own Prospect 4K for windows. Footage was shot with the SI-2K, and on my windows laptop converted from AVI to MOV with HDLink. I downloaded the Cineform codec for Mac (cineform footage seems to be working fine) but if I drop stock footage or try to make titles or even leave a black space I get those Cineform logos. Help? Thanks! |
FCP always renders. If you have a CineForm timeline, FCP will render blank frames and various slugs which will create the watermarks. If you add non-CineForm material, FCP will render it before you can play.
Thanks.
Not sure I follow. In fact I don't follow. Is there a way to work with other footage on a Cineform timeline or do I have to convert it all to Cineform? Cheers. Edit: I didn't have this issue in Premiere Pro. I could import stills and create black frames without this issue. Then again, I've probably had a Cineform license for P2K or P4K on any machine I've used. OK, I guess I get it. That sucks, a little. |
You should be able to use non-CineForm source in a CF timeline. FCP will say the material needs rendering before it will play, and once you do that, you get the logos. Black is not just black, but a black frame that is encoded using the CineForm encoder, and repeated as needed for a slug.
It sucks, but that is the FCP does things. You might try to drop everything onto a ProRes timeline instead. It often will let you play CineForm, and the render bits - black frames and titles - will not have watermarks. |
Thanks, yes. That's what I've had to do. I have P4K on my windoze laptop, but not on the Mac I'm editing on. I'm basically just rendering each clip that I drop into the prores timeline, and I have another Cineform timeline where I work with the bulk of the material for rough assembly.
Cheers. |
