HDLink audio problem.
I am converting EX1 .mp4 file to Cineform AVI using HDLink.
Source is 1920x1080 50i Destination is 1920x1080 23.976p with setting in HDLink "rate change 25 to 23.976" and "deinterlace on". After the conversion the cineform avi file audio seems got cut off at around 75%. First 75% has audio, but the rest 25% no audio. Original mp4 file no issue with audio (I've checked of course). Anyone having this issue before? I'm trying using HDLink prospectHD latest build. |
If you do the conversion without the rate change, do you have the same problem?
Please try that and then file a ticket with support so we can get more information on your system, etc. Thank you. |
Without the "rate change", audio is fine. I also tried to convert EX1 .mp4 to "MXF for NLEs" using ClipBrowser software. Then take this MXF file to convert to CFHD using HDLink with "rate change", everything work fine. Audio is fine.
The problem only occurs if I straight convert EX1 .mp4 file to CFHD in HDLink with "rate change". |
