First Light corrected .MOV's playback only 15fps on Macbook Pro 2.4Ghz
Yes, I am aware that the minimum system requirement listed on Cineform.com is a minimum of 2.66Ghz Core2Duo. And, that performance will suffer with lesser computers.
If I replace my existing laptop with one that meets the minimum system requirements, which I am prepared to do, will it playback my Cineform files, with "active metadata" such as white balance and gamma adjustments, and possibly a 3D LUT, in realtime from my Final Cut Pro timeline, out to an HD-SDI monitor, in real time, at 30FPS? If not, what kind of Mac do I need? This capability is impressive to me. I don't mind buying a new computer to have it. |
Any on the current i7 based Mac Pros will do it, even better with a Kona card (with the new CineForm aware AJA drivers -- due out about now.)
You said "out to an HD-SDI monitor" so I assumed a desktop/workstation. Laptop solutions via AJA IOExpress have not been tested yet, plus I'm not sure if they would be fast even to do a 3D LUT (the base Active Metadata stuff should be okay on a sweet laptop.)
Thanks for the advice! |
Oh nevermind. My 6 month old Macbook Pro can't even play non- First Light Cineform files at more than 15fps. Even on the laptop screen. Without any external monitors connected. Good thing you included the Pro Res option in NeoScene! ProRes HQ plays just great on my laptop screen. And on my 17" HD monitor.
Of course, I can't understand how ProRes HQ files play just fine, but the much smaller Cineform files limp along, at half speed, on the same hardware. At this point, First Light really, truthfully does not help my workflow at all since the files need to be playable on other computers, besides big expensive workstations. Is my experience consistent with your other users? OR can some laptops play these files? |
Hi
Fullrez on laptop is not possible as of now. It should play fine in the Canvas in FCP even with 3D LUT, but it will not play out even cinema desktop at 30fps. The smaller file is MUCH better quality than ProRez and it uses different compression algorithm (Wavelet VS DCT) what takes much more computing power not to mention the active meta-data that also needs to be applied. Different beasts for different needs, also the Firstlight stuff is bleeding edge (and it is bleeding in many cases) so expect to need ludicrous HW at the beginning to get the max out of this. NB! Make sure you use bilinear debayer for 8bit -Kaspar |
BTW, CineForm's decompressor is about to get measurably faster in the next few days with our next Mac release. The performance improvement will probably be appreciated most on laptops and "tired" machines....
The new builds were posted on Friday. Build 91 (2.3.8.91) is twice as fast on a Macbook. 1080p 29.97 plays full frame rate in QuickTime on a Macbook 2.2 Ghz using about half the processor compared to 15 fps on the previous version with the same processor use.
If you change the White Balance in FirstLight, it does take more processing, so QuickTime will drop the frame rate in half. |
David.
I might have missed something by reading too faast or am just delusional. A comment above makes me ask - Is there a tool in Prospect for PC which will export a Mac usable ProRes HD file for somebody at another end who does not want to populate his FCP edit suite with plug-ins? Or is a Quicktime .mov file the only option. If I could do this out of the SI2K I would be in even sweeterer pigheaven. I understand and accept that such a function would compromise your commercial viability as people with established FCP edit suites would simply not move out of their way any more than they think they need to. |
| All times are GMT -6. The time now is 12:27 PM. |
