-   CineForm Software Showcase (https://www.dvinfo.net/forum/cineform-software-showcase/)
-   -   First Light (mac) issues (https://www.dvinfo.net/forum/cineform-software-showcase/235536-first-light-mac-issues.html)
Brian Parker May 17th, 2009 08:54 PM
I tested First light for the first time last night. Here is what I saw:
1. Apply gain and the video flickers widly between effected and uneffected frames.
2. White Balance "Pick" doesnt seem to do anything.
3. I havent read the help file yet, but couldnt see a way to apply all the adjustments done to one file onto multiple other files.
Suggestion:
The interface is very nice, but isnt there any way we could have it as a plugin within Premiere Pro/AE. It would be so much faster if we could apply it to source clips in there, rather than finding them on the timeline.
Craig Davidson May 17th, 2009 10:33 PM
The video flicker is caused by your file having more than one GUID in the stream. How was the file generated?
If you want to apply settings to other clips, "Copy" with one clip selected, then select the clips you want to change and "Paste".
White balance "pick" is not yet implemented.
Brian Parker May 18th, 2009 10:52 AM
I used Remaster to convert some avchd (Canon HF100 Highest quality) files to cineform movs.
David Taylor May 19th, 2009 10:46 AM
Brian, will you please send an HF100 file to support at cineform dot com using YouSendIt - Send large files - transfer delivery - FTP Replacement You can send up to 100MB for free. We only need a short segment.
John Palaganas May 22nd, 2009 01:30 PM
Same issue for me.
How do I remove the other GUID so I can only have 1 GUID on one footage?
